I have a question?
Old Apr 17, 2008 | 11:34 AM
black04silverado's Avatar
Exclamation I have a question?
will cutting my cats off set my check light? one of my cats now is messed up and it set off my light i have a 2004 silverado 5.3 and i just need to know if i cut them off if it will fix my problem or make it worse?
Old Apr 17, 2008 | 01:13 PM
00ChevyScott's Avatar
Wearin' da big hat
yes it will throw a code, it will throw p0420 and p0430 if i remember correctly. This is 2nd o2 bank 1 and bank 2. all they do is measure temperatures, and do not affect AFR at all, so it will run the same as before, you'll just have a check engine light untill you get them tuned out.
Old Apr 17, 2008 | 01:23 PM
aaronk227's Avatar
It will actually run and sound a little bit better, at least mine did. Any tuner can delete those two codes pretty cheap. i'd say do it. Or you can go on ebay and buy a replacement cat.
Old Apr 17, 2008 | 03:54 PM
brobradh77's Avatar
do it and have them tuned out...
Old Apr 18, 2008 | 02:00 PM
how Do i get the 2 codes turned out ?
Old Apr 18, 2008 | 03:59 PM
Shahnp1's Avatar
Thumbs up
You will need to have them removed out of your trucks tune. You should give Wheatley a shout on here he comes highly recommended by alot guys on here you can send him a PM or check out his website. look to your right a link should be on the side bar. There are several tuners on here that are sponsors of the site. hopefully that will point u in the right direction.
Shahn
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
