i got my pacesetters long tubes installed
Old Dec 3, 2006 | 11:47 AM
xdanny510x's Avatar
Default i got my pacesetters long tubes installed
i got my pacesetters long tubes installed installed on my 2005 silverado 5.3 about a month o so and i keep hearing this noise like something is loose everytime i hit like a bump it makes that noise and it comes i belive from my passenger side . I did not have this problem when i had my shorties on! what do u guyz think it could be?
Old Dec 3, 2006 | 11:50 AM
TXsilverado's Avatar
check how close the header tubes are from the frame rail.
Old Dec 3, 2006 | 12:00 PM
Rhino79's Avatar
9 Second Club
Also, how close is the exhaust pipe to the crossmember?
LS1TRUCKGUY's Avatar
i know my primarie is no more than an 1/8 inch from the framerail. is your truck 2x4 or 4x4? maybe you got the wrong ones? just trying to throw some ideas out there.
Old Dec 3, 2006 | 01:25 PM
jakebdb56's Avatar
loose exhaust hanger maybe?
the passenger side primaries are about 3/32" off the framerail but they'v never hit/rubbed. no signs on the headers or the framerails indicate it. maybe you didn't torque down the trans x-member bolts well enough? that'd be no bueno
Old Dec 3, 2006 | 02:06 PM
xdanny510x's Avatar
my truck is a 2wd . it just seems to rattle alot i was thinkin it was my exhaust but i unno. i got true dual exhaust n **** but yea if it is touching the frame what should i do? or the cross member what should i do?
Old Dec 3, 2006 | 02:24 PM
Rhino79's Avatar
9 Second Club
Have who ever did the exhaust work fix it.
Old Dec 3, 2006 | 02:32 PM
xdanny510x's Avatar
i had the exhaust done at one shop plus and plus where i got my headers installed at this mechanic shop all they did was take off the shorties and cut the cats off installed the long tubes and got 2 pieces of pipe and welded it. so should i redo the whole piping over again?
Old Dec 3, 2006 | 02:42 PM
Rhino79's Avatar
9 Second Club
Have you found where it is hitting?
Old Dec 3, 2006 | 04:13 PM
xdanny510x's Avatar
it sounds like its hitting close to the motor . it sounds like from the right side header .i dont know if its hitting the frame . Or maybe it could be a motor mount.. is thier anything i can put between the frame and the header so it wont hit and maybe start crossing out the possibliites?>
