I got my fuel pump today....
Old Mar 25, 2009 | 01:03 PM
fastrt's Avatar
11 Second Truck Club
Default I got my fuel pump today....
I asked questions and researched pumps for returnless systems, and only found guys that hacked up their buckets and or had to take their tanks down several times for different problems they ran into. I found a kit that comes in the maggy kits that is basicly plug and play. comes with the right hose, fitting, clamps, and a walbro gss340 255lph pump. no cutting the bucket, or hacking the fuel lines. the only thing I do not like is the connections to the pump, and lingenfelter has a plug-n-play harness that I may buy before I put it in. the only part that I am going to do different is pull the bed off. here is the instructions and pics of my kit.http://www.magnacharger.com/pdf/manu...00-2003-06.pdf
Old Mar 25, 2009 | 05:32 PM
CashDudeHomie's Avatar
It's the 99-03 return system guys who have to cut up the buckets. Everyone else already knows about the one you bought.
Old Mar 25, 2009 | 05:55 PM
dlt76028's Avatar
why did you buy a new fuel pump? the oem one is by far the best and will supply plenty of fuel for you.
Old Mar 25, 2009 | 06:06 PM
hirdlej's Avatar
+1 - the factory one is more than adequate. Aftermarket is seldom better than GM.
Old Mar 25, 2009 | 06:30 PM
fastrt's Avatar
stock is ok for now, but I have future plans. and I have seen on here where some guys hack up returnless buckets too.
Old Mar 25, 2009 | 07:09 PM
charcold-bowtie's Avatar
I havent seen much posted on the returnless pumps. I did notice my fuel psi drops like 7 psi during a WOT run, OLSd still runs at 11.5 AFR, so its done that for a while.
Old Mar 25, 2009 | 09:28 PM
fastrt's Avatar
soon enough I will be taking fuel from the rails so I will need the extra flow...
Old Mar 25, 2009 | 09:45 PM
A Low Dime's Avatar
13 Second Truck Club
Oh?
Old Mar 25, 2009 | 10:18 PM
marlboroman71818's Avatar
im fixing to make a full write up on my bosch 040 intank install on my 05. check the general discussions forum
Old Mar 25, 2009 | 10:24 PM
NegraRCSB2X4auto's Avatar
my bosch is working fine with the stock intank regulator on my returnless system.
