I all ways think the worst!
Old Dec 3, 2006 | 01:02 PM
TURBO8's Avatar
Default I all ways think the worst!
I thought I blew the motor on the dyno with the 680hp and 780tq run. It was just a fuse. I thought I had a bad piston ring when I seen on the boost gauge that I only had 5lbs of vacume (20 is normal)and couln'd get more than 10psi of boost at the track. It was a vac leak. I thought that if I had a vac leak it wouldn't idle right, but it was normal. I thought that I broke my trans, because I couldn't get second gear. I didn't, I broke the shifter and the bushing was swivleing so it looked like I was grinding 2nd gear but I was some where in nutral. The trans is a ok. Somebody up there likes me.
Old Dec 3, 2006 | 01:22 PM
jakebdb56's Avatar
man that's crazy. glad to hear its all ok.
those numbers are pretty impressive for a turbo 5.3. are you using the stock bottom end? i've been wondering how much the stock bottom end could hold up to before just disintegrating
jake
Old Dec 3, 2006 | 02:27 PM
TURBO8's Avatar
Yeah! stock short block. THanks
Old Dec 3, 2006 | 02:51 PM
jakebdb56's Avatar
np man. maybe someday once my warranty runs out I can turbo my motor, until then its all boltons for me
Old Dec 3, 2006 | 05:54 PM
TXsilverado's Avatar
expecting the worse is better than planning the best and finding the worse IMO
Old Dec 3, 2006 | 06:07 PM
TexCrew's Avatar
im the same way at first. but after i calm myself down. i look for little stuff like that. sometimes its just some small detail that gets in the way.
Old Dec 3, 2006 | 08:12 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Your the same type of person as I am, get something going good, something goes wrong and automatically exspect the worse. 99% of the time its a little cheap fix
Old Dec 3, 2006 | 10:10 PM
Wilde Racing's Avatar
How do I change this text
Sweat, glad to hear about the trans... Though I was looking forward to your truck running some KILLER times with a auto.....
Old Dec 4, 2006 | 12:16 AM
jakebdb56's Avatar
when building the dune buggy all the fab stuff was easy, but once it came to firing up the motor we freaked since we never got it to start. comes out that the relay off the starter switch was bad out of the box. I soldered it back together and it fired up. i'd never built a motor before then and my buddy and I thought that perhaps we did somethin wrong, but we fixed it.
nabozny21
Oct 17, 2015 07:47 PM
Wolftrk99
Oct 2, 2015 08:17 AM
blackedoutchevy22
Oct 1, 2015 08:07 PM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
94f150
Sep 28, 2015 05:28 PM
