Hyperlube Supercoolant
Old Jul 13, 2006 | 05:56 PM
SS Crew's Avatar
Default Hyperlube Supercoolant
I'm going to pull my boat through the desert this weekend to bring it home for service and saw this stuff called Hyperlube Supercoolant at the auto part store. It's supposed to bring down coolant temps down about 20 degrees. Is this stuff for real, does it really work, anybody had any experiences with this stuff? Is it compatable with Dex-Cool antifreeze?
Lemme hear from you.
SS
Old Jul 13, 2006 | 06:00 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Sounds like the same concept as "Water Wetter" I use it in my intercooler. Its actually supposed to work but I've never tested it by taking temp with and without it.Water Wetter is about $7 a bottle and you only need one for your system. If this stuff is the same it should work.
Old Jul 14, 2006 | 10:12 AM
moregrip's Avatar
what a rush!
I added water wetter to my cooling system. If there was any difference it was not perceptible. That said, where some of these products benefits might be more perceptible is in the more extreme conditions.
Old Jul 16, 2006 | 11:50 PM
SS Crew's Avatar
I asked this question because when I tow my boat (5000 lbs.) through the desert in 110+ degree heat it does fine, it stays at about 200 degrees until I hit the hills and holding the speed at 75 mph, it'll downshift to 3rd, but the coolant temp rises up to 240. I'm still 20 degrees from the overheating, but I still don't like seeing the coolant temps that high. This is why I was wondering if adding something like the Hyperlube Supercoolant or the Red Line or Royal Purple "water wetters" will help in this situation and lower my temps under these conditions.
Thanks for your input.
Old Jul 17, 2006 | 12:47 AM
moregrip's Avatar
what a rush!
just might, give it a try and report back. I'm curious as well. Your other option is a higher flowing water pump(but they aint cheap)
Old Jul 17, 2006 | 06:43 AM
I put in Red Line water wetter just a day or so ago. It does seem to pull the temps down about 15* or so. At least as far as I have had the chance to test it. I used more than 1 bottle.
Also, the temps that you see on your dash gauge, if that is what you are using, could be quite a ways off from actual. For example, my ECT gauge reads 180, but if I look at it with a scan gauge or EFILive, it reads 162 or so. And...the difference is not linear either. Meaning it is not 18* off accross the board. Tranny temps read similar. I guess what I'm trying to say is you may not actually be as high as you see, but going the other way, you could be higher. Getting that high in temp, I'd want to know just how accurate my gauge really was.
You may also want to look into e-fans. I have Flex-a-lites and they pull over 5000cfm. Not sure what '05 factory fans pull, but many add those instead and you can have either controlled by your PCM. My stock clutch fan just cooled okay compared to the e-fans. Just a suggestion.
What do your tranny temps look like during that kind of towing?
Old Jul 18, 2006 | 05:53 PM
SS Crew's Avatar
On the hills the tranny got up to about 190-200 degrees, then on straights it hovered around 185 degrees. Around town not towing anything it usually sits aroung 160+. Back in November I had the trans serviced. I told them I wanted the fluid and filter changed, but came back as being flushed. So I don't know if the filter was changed. -- This is a GM recommendation.
Old Jul 18, 2006 | 06:13 PM
thunder550's Avatar
High on diesel fumes
Sounds like exactly the same problem I have been battling since I installed my e-fans. Are you on a clutch fan or e-fans? I will be reinstalling my clutch fan here in the next couple of days to see if that fixes the problem. Going back to the lake on Thursday so I'll be able to report on any changes after that.
And as BenKey said, there's a "dead spot" on the ECT gauge in the dash. It will read right around 200 when actual temps are from about 185 to 220 without moving.
Old Jul 18, 2006 | 06:15 PM
thunder550's Avatar
A standard fluid change just involves draining the tranny pan and refilling it. In a flush, they get ALL of the old fluid out of the tranny, including the valve body and converter, which doesn't normally drain when you pull the drain plug out. If they did a flush you got a full fluid change and a new filter.
As a side note, my tranny temps have been off the scale because of my ECT temps and the fact that I still have the tranny lines running through the radiator. I plan to take the radiator out of the loop soon and just run my pair of standalone tranny coolers. I have seen tranny temps as high as 240 when my ECT's got up to 248.
nonnieselman
Mar 25, 2008 07:21 PM
BlackSS04
Jul 7, 2007 12:01 PM
2001Z71
Dec 21, 2005 09:42 PM
Mr. Sandog
Sep 21, 2005 03:51 AM
Chingon
21
Sep 15, 2003 08:45 PM
