HUGE problems, need help ASAP
Old Nov 7, 2008 | 01:45 PM
  #31
00ChevyScott's Avatar
Wearin' da big hat
just put a new fuel filter on it. Didn't fix anything, it sounds worse now.
It sounds like only 1 cylinder is firing now
Old Nov 7, 2008 | 01:53 PM
  #32
SpinalTap's Avatar
Timing chain slippage or distributor not bolted down?
Old Nov 7, 2008 | 01:56 PM
  #33
Wearin' da big hat
I just checked the front plug on both sides, look fine.
And no timing chain slippage, it looked fine when I did the cam swap, and there is no distributor.....
Old Nov 7, 2008 | 01:59 PM
  #34
GMCtrk's Avatar
oil pressure and voltage are good?
Old Nov 7, 2008 | 02:04 PM
  #35
SpinalTap's Avatar
How about a MAP/MAF disconnected, or vacuum line leak? Those would make the truck idle crazy and feel like its running on less cylinders.
Old Nov 7, 2008 | 02:06 PM
  #36
Wearin' da big hat
Yep, normal oil pressure and no voltage drop besides the lack of idle speed for the alternator to run good.
****, ive gotta go to work guys. I'd really appreciate it if you guys kinda debated this out and ill check back later
Checked the oil dipstick and it still looks fine, no coolant loss that im aware of. the front spark plugs on each side (easiest to check) look fine, and it will hardly even hold on idle now. It is progressively getting worse. I have a whole nother set of coils to try if I need to, but it is throwing a multiple random missfire code. I will drop the tank and drain it when I can and see if that was it. I also have a good set of injectors to swap over if I have to.
thanks alot guys
  #37
trever1t's Avatar
2nd fastest 5.3 ECSB
injector?
lol, you beat me to it, try swapping the injectors on the misfiring cylinders.
Old Nov 7, 2008 | 02:07 PM
  #38
Wearin' da big hat
Originally Posted by trever1t
injector?
it really honestly sounds like 1 cylinder firing. Do you think 7 injectors could go bad?
Old Nov 7, 2008 | 02:08 PM
  #39
Wearin' da big hat
injector?
it was showing cylinder 2 at first, then it swapped over to multiple missfire. ugh
going to work, will check back later!
Old Nov 7, 2008 | 03:01 PM
  #40
meatwad's Avatar
Fast lane preferred
check your valvetrain....spring or bent valves?
