HUGE problems, need help ASAP
Old Nov 7, 2008 | 10:22 PM
  #51
00ChevyScott's Avatar
Wearin' da big hat
Well we took the truck around the block to see if it got better after work and it died in the driveway and wont start up now. When I crank it, you can hear 1 cylinder try to fire but it wont kick all the way over.
I'll buy a fuel pressure gauge tomorrow at work and check it. Where is the port on the fuel rail I can connect it to? Does 118,000 miles on a stock fuel pump sound about right? I can still hear it prime, but I have notice it sounds a little funny now. Its a bit more higher pitched of a whine.
Old Nov 7, 2008 | 10:37 PM
  #52
GMCtrk's Avatar
looks like you found your problem hopefully. 146k here and still on the stock pump.
Old Nov 7, 2008 | 10:39 PM
  #53
JakeBrakeIH's Avatar
on the passenger side of the motor...cant miss it...just take off the cap and put the gauge on it...
Old Nov 7, 2008 | 11:04 PM
  #54
Wearin' da big hat
well I think i found the problem. It was a mix of things.
1. bad gas/clogged fuel filter
2. loose spark plug wire (i dont know how that happend ) thanks for the idea of using the temperature gun btw
3. Ran it out of gas when me and my dad were driving it around the block I guess my truck gets worse gas mileage than I thought, and my gas gauge hardly ever works anymore
Anyways, it sounds like its running better, gonna dump more b12 and lucas crap in it tomorrow and see how she does.
Thanks for all the help guys!
Old Nov 7, 2008 | 11:17 PM
  #55
trever1t's Avatar
2nd fastest 5.3 ECSB
It was out of gas??
Old Nov 7, 2008 | 11:19 PM
  #56
Wearin' da big hat
Originally Posted by trever1t
It was out of gas??
thats what happens when my "high quality" GM gas gauge sending unit is fugged up and tells me its got 1/2 a tank when it really doesnt
Old Nov 7, 2008 | 11:34 PM
  #57
A Low Dime's Avatar
13 Second Truck Club
Old Nov 7, 2008 | 11:37 PM
  #58
A Low Dime's Avatar
Old Nov 8, 2008 | 12:16 AM
  #59
A Low Dime's Avatar
well I think i found the problem............Ran it out of gas.......
Just imagine that this guy is out in the world everyday!!!!
Old Nov 8, 2008 | 02:47 AM
  #60
Fastlane50's Avatar
Those handheld temp guns are money. I picked that trick up from my cousin's engine builder for his circle track race car. Anytime they get a misfire or something isn't quite right, the temp gun always tells which cylinder(s) are significantly colder than the rest. Glad that was of use to you.
