hpp3 leaves signature even when removed
I just got back from kenne bell. they took the whipple piggyback system off my truck and rplaced it with new injectors and reprogram my computer. I used to run a hpp3 but I took it out and put everthing back to stock before I took it in for the piggy back replacement. They told me that the hpp3 had left some tables changed and it plays havoc when trying to reprogram again based on the assumption that all is stock inside, when in fact things are not. This is after Its supposed to have been taken out,but it just takes most things out and leaves traces that are not good for programmers that follow.
Performance Trucks Sponsor
I would be very interested in knowing what tables were left behind. I have no idea what they are using to edit a pcm. 99% of the tables hpp3 modifies are viewable by edit, I've never seen any traces. Of course i'm only using ls1edit.
keep us updated on the power increase,
allen
allen
When they dynoed my truck with the whipple computer and secondary injectors the stock speed limiter did not engage at 98 mph. it ran out to 111 before it kicked in.It did not take out the modified speed limiter completelly. I had used the 128 limit with hpp3. I also still used the hpp3 to raise shift points when i was running the stock whipple set up. their is now some wierdness in the 2/3 shift which showed a downward spike on the dyno at shift. this might be caused by the large power increase that resulted from the conversiion to the bigger injectors with their reprogram. It now is hard to get traction well into 2nd gear. or any where under 60 or so. peaked at 418. at the wheels.thats a shift spike . sustained peak hp was 332. or so. different dynos produce different numbers with the same car , the whipple only made 280 so the peak is up a bunch but even more at 4000 its closer to 70 or so. your name was part of our conversation to day . when i said nelson tunes they said oh you mean farm truck! everybody knows everybody in this interspace world. i will look into what he reprograms with on my next visit out there.
I can't help to ask ... did they criticize his tuning?
what i want to know is if the hppIII is'nt removing some items, if you return it to stock and sell it are those options still available to program in the new vehicle ? i'm trying to sell mine and i'd hate to think i sold someone something that is not 100%. anyone heard of anyone buying a used hppIII without all the tuning options of a new one ?
At this point someone from Kenne Bell started posting, making claims about warranty, liability, and legal issues with that KB warning sticker (which was being used as a signatiure pic). A few members made comments about programming, the KB guy took the bait, and a little famtruck / KB storm errupted. Fairly quickly, the KB folks saw what was happening, and made some defensive manuvers then tried to smooth things over. That was KBs introduction to Allen.
If you have before and after dyno charts, I would like to see them. If you don't have a way to post them, email them to me and I'll do the hosting and post them up here in this thread.
