HPP3 dyno results
Old Mar 14, 2002 | 12:02 AM
oxidizr's Avatar
Moderator / Sponsor
Default HPP3 dyno results
Testing completed....
HPP3 results:
The first three passes of the day were to get some solid baseline numbers.
Peak RWHP N/A: 278.2
Peak RWTQ N/A: 318.0
The next three passes were after HPP powertuning was installed. The power tuning for 93 octane was used along with 160* stat.
Peak RWHP N/A: 291.2
Peak RWTQ N/A: 325.4
Final analysis:
13 RWHP
7.4 RWTQ
The power was made evenly across the entire tested curve and even opens up some above 4700 rpm.
HPP3 = worthwhile mod
Richard
Old Mar 14, 2002 | 01:14 AM
GMCJimmy's Avatar
Default Re: HPP3 dyno results
I have a HPP3 on my 2002 Sierra 5.3. I was wondering if the truck tends to wnat to choke itself b/c it thinks it is too cold. When I put a computer mod on my 86 vette and a 160 thermostat it kept fouling plugs. Will this happen to the sierra?
Old Mar 14, 2002 | 08:31 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Jimmy, a 160F T-stat will typically make our motors run at around 185F, which is not considered "cold". No problems at all, and you should get less knock retard in most cases.
Tony
Old Mar 14, 2002 | 10:09 AM
Former Vendor
Thanks for the great info! Where was peak HP and TQ for both graphs?
Old Mar 14, 2002 | 11:49 AM
oxidizr's Avatar
Moderator / Sponsor
Trevor D
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">The next three passes were after HPP powertuning was installed. The power tuning for 93 octane was used along with 160* stat.
Peak RWTQ N/A: 325.4 </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">----
EDIT
I didn't understand what you were asking for the first time I responded...
291.2 RWHP @ 5200 rpm (from 4700-5400 it makes 290+)
325.4 RWTQ @ 4000 rpm (from 3000-4500 it makes 300+)
I was really suprised how much the programming flattened-out the curves.
Richard
<small>[ March 14, 2002, 11:56 AM: Message edited by: oxidizr ]</small>
Old Mar 14, 2002 | 03:14 PM
Nine Ball's Avatar
LS1Tech Co-Founder
HPP3 tuning tends to improve the F-body low/midrange output also. Doesn't do much for higher rpm though.
Tony
$A_Money$81
Mar 27, 2023 10:25 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
norris_83
Sep 9, 2015 04:14 PM
