Are HP Tuner and EFI live the top 2 choices
#31
OK you guys are confusing me HPTuners can set pin 33 settings? For A/C pressures, fan shut off at highway speeds, etc. on 03 up PCM?
#32
When I finally get my silverado fans on, thats how i plan to wire them.
#33
Nope, no A/C pressures in HPTuners and it appears no highway speed settings. Not sure how that would work either, since the MPH speeds are all 0 by default in the PCM.
#34
If you have factory e-fans, you can change the settings for ECT only. Why do people want to have a/c pressure settings for their fans? I'm just curious.
BTW, HPTuners is working on adding support for what you're wanting to do that will hopefully be out in the next release.
Here's a screenshot of what your fan settings will look like:
is HPTuner can enable pin 42 ECT only, and can set only on/off for ECT?
#35
#36
#40
No, it looks like pin 33 CAN be enabled. The only trigger available those is ECT in HPT. No MPH or A/C pressure settings that I can see.
