hp issues... need advice
Old Jul 5, 2013 | 01:25 PM
grm1738's Avatar
Default hp issues... need advice
guys.
i just ran into an issue with my build... i started this project wanting a 1000 rwhp truck that was a sleeper... the more stock looking the better.. well i built my motor and trans for a f2 procharger by there specs. i have recenetly found out that this procharger is in no way shape or forum for sleeper vehicles. it is loud and not mistakable. if i go with there ds series which is still quiet i am limited to around 700ish rwhp..
Do yall know of another way i can 1000 hp while still being a sleeper...... what other superchargers will give me the hp and remian quite at idle... i have been thinking about turbos but i dont really want the issues related to turbos.. what options do i have...
Old Jul 5, 2013 | 04:20 PM
Whitecrewcab's Avatar
Not much, just about anything that moves enough air to make that much power other than a turbo is gonna be noisy.
Old Jul 5, 2013 | 06:40 PM
14psisupra's Avatar
Turbo turbo turbo
Old Jul 5, 2013 | 07:14 PM
darnie's Avatar
turbo.... run around with low boost then crank it up if ya wanna get crazy!!!!!!!!! :0
Old Jul 6, 2013 | 04:54 PM
grm1738's Avatar
what issues are yall having with turbos...
Old Jul 6, 2013 | 05:04 PM
silverado6.2's Avatar
Turbo's are pretty reliable, just ask any truck driver on the road. They run 24hrs A day on our compressor engines at work and generally outlive the engine. The only failure we have had with a turbo was due to an oil supply line coming loose.
Old Jul 6, 2013 | 06:48 PM
Atomic's Avatar
I have a gauge for that
Hows this for your goals?
Anything besides a turbo wont give you what you want though...unless you want to hit it with a 500 shot.
Old Jul 6, 2013 | 11:32 PM
smokeshow's Avatar
Mod with training wheels
I'm not aware of any particular 'turbo-related' issues.
Old Jul 7, 2013 | 01:07 AM
darnie's Avatar
ya turbo would be your best bet
you have any experience with turbos??? hehehehehe btw between u and joey i got alot of work to do lol
Old Jul 7, 2013 | 12:31 PM
grm1738's Avatar
i really need to start doing some research on it..is there any particular company that has premade kits to install...or are they all custome made.
ATOMIC.. i have been following your build... that is exactly what i am going for. i was just going to go the charger route.. what cost am i looking at going with a 80ish mm turbo and the hole set up... also would i loose my 1200 exhaust....
