how will this cam work???
Old Aug 25, 2009 | 09:24 PM
borntobewild99's Avatar
Default how will this cam work???
Comp cam 265LrRR12
specs at 215/223 @.050"
.607/.61 lift
112 lsa / 110 icl
99 silverado 5.3 ext/cab 4x4, shortys, true duals, k&n cai, superchips(good scan tool lol), vette servo, stage 3 shift kit, 4.56's eaton posi, 33's very heavy truck but still will take a hemi anyday
i want to keep stock converter
Old Aug 28, 2009 | 07:28 AM
04Crew's Avatar
Should work OK. However, due to the size of your tires and the weight of your truck, your 4.56's are the only thing keeping me from saying that a bigger stall would be needed. If you have any intentions of increasing tire size you might consider something a little more tame (or a small stall). Also, if you are running stock heads the additional lift is of no real benefit. The flow on the stock heads tapers off significantly over .500" of lift. The .6xx lift cam that you listed will put a lot of additional stress on your valvetrain for minimal gain. Lastly, a tune will be required.
ARC
57
Feb 21, 2022 10:54 AM
Castro45
24
Jul 31, 2015 07:13 PM
elpyro89
Jul 28, 2015 05:51 PM
06 4.8
Jul 15, 2015 07:17 PM
4B11T
Jul 13, 2015 03:48 PM
