How will this cam do in my truck.
Old Oct 28, 2003 | 02:09 PM
FILE's Avatar
Default How will this cam do in my truck.
How will this cam do in my truck? 214/218 .540/.550 114lsa
I am serously considering this cam for my truck.
Thanks.
Old Oct 28, 2003 | 03:45 PM
Hit Man X's Avatar
It'd be pretty nice! Power gains all over...I'd still go with some stall first to avoid any (if) flat spots in the power down low. The stall would make the best of the cam.
The 114lsa will give you good idle vac and shouldn't require too much tuning. But if you sell the HPP3 that will get most of the money for a tune.
Old Oct 28, 2003 | 04:59 PM
BigTex's Avatar
That sounds interesting. Probably a good choice. Which manufacturer will make it? The lift looks smaller than a comp XE high rpm lobe, but more than the plain XE lobe. Almost what a thunder racing lobe might be at those durations.
Get it with at least 2 degrees advance ground in and up to 4 degrees. The more advance, the better the low end, but you are trading peak HP.
Old Oct 28, 2003 | 06:34 PM
FILE's Avatar
this is a Comp Cam
Old Oct 28, 2003 | 06:35 PM
FILE's Avatar
this is a Comp Cam. What would be the RPM power range for this cam?
Denali08
Aug 9, 2015 04:34 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
Matt331
Jul 26, 2015 09:40 PM
ls2 dude
Jul 25, 2015 11:22 PM
all_individual
Jul 13, 2015 11:01 AM
