how to tell if you rearend is broke?
Old Feb 1, 2003 | 06:27 PM
redaddiction's Avatar
Default how to tell if you rearend is broke?
Ok i know my trans is gone cuz there is fluid everywhere but how do i tell if my rearend is broken?
Marc
Old Feb 1, 2003 | 06:33 PM
sleepersilverado's Avatar
Default Re: how to tell if you rearend is broke?
do you have a one wheel wonder or what info would be good. but for the most part it will make noise. most the time clicking and in my buddies recient case loud thumping that got louder as you go = 3 teeth gone off the ring gear. but for the most part noise.
Old Feb 1, 2003 | 08:28 PM
it has a powetrax lsd i'm wondering if i could take the cover off and see anything would i be able to?
marc
Old Feb 1, 2003 | 08:39 PM
StupidFast's Avatar
What do you have done to your truck? A rearend and a tranny? I am proud.
<small>[ February 01, 2003, 08:40 PM: Message edited by: StupidFast ]</small>
Old Feb 2, 2003 | 12:27 AM
Well i'm not sure about the rearend i want to check it though but mods are going to be listed in sig
marc
Old Feb 3, 2003 | 08:20 AM
Seeing Red Again's Avatar
To do a visual check:
put rear on stands, disconnect drive shaft, drop diff cover and spin the ring gear. Look for broken or missing teeth on the ring gear or pinion gear.
With a limited slip, if you broke an axle shaft you would just loose all or most movemement from the vehicle when it's in gear. If it's a pinion shaft or carrier broken, again no forward movement when under power in gear.
lukn4trbl355
Oct 21, 2015 11:19 PM
Velocity1
Oct 2, 2015 08:01 AM
Wrecker 426
Sep 30, 2015 09:39 PM
97_ek
Sep 23, 2015 09:16 PM
600 horses
Sep 10, 2015 11:01 AM
