How to order a custom grind cam?
Old May 11, 2008 | 01:35 AM
InchUp's Avatar
Originally Posted by BlackGMC
I looked through that and wasn't impressed by the explanation given to someone looking for a grassroots description of how lift can help and hurt a motor for a given application. Simple answer: More lift = more cylinder pressure = smile on your face from increased torque. Smile on your face usually means excess wear on the valvetrain too. But, ya gotta pay to play and anything under .600 for lift will be a cam that lasts at least 30k miles without wearing the springs out.
Browse through the bold text to narrow down what you want to read. Trying to cram all of this into your head at once leaves you with a headache at first.
http://www.popularhotrodding.com/eng...ecs/index.html
Old May 11, 2008 | 01:44 AM
BlackGMC's Avatar
Resident Retard
Here is another explanation for comp...
XTREME RPM FOR LS1
Designed with Xtreme Energy™ Technology to provide excellent power with the LS1’s enhanced cylinder head design and high RPM performance. These provide outstanding low RPM torque with increased stability when coupled with the LS1’s larger base circle and 1.7:1+ rocker ratios. High Lift versions are excellent for use with improved heads, manifolds and the new COMP #26915 and #26918 valve springs.
Old May 11, 2008 | 06:23 AM
viciousknid's Avatar
Where's the Beef?
The more lift you have the more air/fuel your letting in. The lower the lift the more economical it will be. If you go with a high lift cam you'll want to change your valve springs.
Old May 11, 2008 | 11:20 AM
00ChevyScott's Avatar
Wearin' da big hat
I'm already probably going with comp 918s, would those last long with a high lift cam?
Old May 12, 2008 | 04:55 AM
Where's the Beef?
Yes the 918's will be just fine up to a .600 lift
Old May 12, 2008 | 08:41 AM
ap2002's Avatar
great choice of cam, my brother has that exact cam but on a 114lsa and its running damn good!! definately go with a 112 or 110, and it should really have all around power plus some lope... my borthers is also an ext cab with 3.42's and it holds its own...
by the way, if you are in the dallas area, you can go to TRTturbo in dallas and im pretty sure they'll can order a custom grind cam...
Old May 12, 2008 | 12:33 PM
Wearin' da big hat
Thats where I got my tune, LTs, ORY, and Tb haha.
He keeps trying to talk me into a 220 or 224 cam. but I'm gonna make him order me the 212/218
Old May 12, 2008 | 02:39 PM
ap2002's Avatar
well if you want lope, then go with 224 on a 112lsa,,, but you'll need a way bigger converter, like 3200+ and 4.10's,,,, but for what you have now you just cant beat the 212/218 on the 112lsa...
Old May 12, 2008 | 11:36 PM
Wearin' da big hat
If it is really worth the swap, id go with a trailblazer converter. and after the cam i am planning on a 4.10/truetrac swap.
Old May 12, 2008 | 11:38 PM
chevyguy7802's Avatar
Should run nice with all those mods! Will be alotta fun out on the street!
