How to neatly drain coolant?
Dumb question, I know...
How can I neatly drain the coolant from my truck? I'd rather not pull off a hose and have the crap go all over the place. I've got bone-headed pets and we use well-water.
I see the little drain nipple thing that you attach a hose to, on the lower part of the radiator, on the drivers side... but... I don't see (feel) a valve there, or a way to turn it on or off.
What's the trick?
What's the trick?
Should be a plastic petcock down there somewhere.
It's a little tough to open the first time and I believe
it's "backward" ("tighten" to open) but go at it firm
but careful, and just let it drool into a drain pan (or
for you high-ground-clearance boys, a bucket).
Word on the street is that '04's don't have the drain petcock.
I intend on getting a better look at this thing that I think is a nipple to attach a hose to, later today. It wouldn't make sense to me as to why they'd put it where I'm looking.
The thing I'm looking at is only visible if you literally dive head first into the engine compartment, and put your head down by the computer / power steering unit. It's on the very bottom of the composite tank, in a recessed area on the drivers side of the radiator. It points directly to the drivers side of the truck. It feels like there is only 3/8 to 1/2" of clearance around it.
Yeah, I took a good look at things last night.
There is the drain nipple thing down there, but you're right, the valve system itself looks like it was never installed and the holes are blocked up like the day it was cast...
There is a small round, hollow, protrusion sticking out about a half inch, pointing towards the firewall... basically right "upstream" from the nipple and at a 90* angle to it. I'd imagine the valve would go there.
Originally Posted by marc_w
Nah, just doing the t-stat mod...
When I changed mine, I only lost about a quart of coolant. Just bent the hose up real quick.
lxcoupe
Sep 25, 2015 12:36 PM
