How much power will a 4.8 hold?
Just wondering how much power a 4.8 will hold up to before it breaks. Does anyone know where I can get the full specs of the 4.8? What kind on internals are in them, forged? I have a freind with a 4.8 and I am building a custom turbo setup for it and Im just wanting to know how hard I can push it. Thanks for any info!!!
Banned
texasterminator is the only person i know of that's blown one up on prolonged supercharging. FAST4.8 blew one up(i have it now) but that was a dry nitrous shot blow up. i'm thinking of building a forged heads/cam/nitrous 4.8 for a different project not a truck.
Adkoonerstrator
No forged internals. I think the pistons are cast
and the rods are powdered metal(pretty strong).
As far as power capacity, the crank and rods should be fine for quite a bit 500+??. I don't know if anyone has destroyed a 4.8 from just power output, more than likely tuning was more a factor. The pistons will take quite a bit as long as they don't see any detonation.
and the rods are powdered metal(pretty strong).As far as power capacity, the crank and rods should be fine for quite a bit 500+??. I don't know if anyone has destroyed a 4.8 from just power output, more than likely tuning was more a factor. The pistons will take quite a bit as long as they don't see any detonation.
Adkoonerstrator
Here is a site with a little info on the 4.8L.
Basically just the bore and stroke.
http://www.gm.com/automotive/gmpower...ehicle/lr4.htm
Ther was a guy that did a heads and cam with prochargert hat was in the 370 range and it died on the pistons I believe. Texas Terminator maybe?
Mine blew up at about 350hp due to a lean n2o shot.
Yea,
Im fairly good with tuning if I got a good system to work with. I plan on using an intercooler and Alky/Water injection on it to keep from burning up the pistons.
I think that I could get 425 RWHP no problem.
Also,
Are the fuel systems on the trucks like an LS1? With the in-tank regulator?
Also,
Adkoonerstrator
The fuel systems are not the same. The regulator is on the side of the drivers side fuel rail and is manifold referenced. Evidently it doesn't raise pressure 1:1 under boost but, does raise it some. I think parish8 said it was like .5psi fuel/1psi boost. Fuel pressure at idle is like 50psi and rises to 59psi at 0 manifold vacuum.
We actually have a nicer fuel system than the Fbodys except for the crappy little injectors GM stuck us with.
An intercooler and water/alky will be AWESOME.
