How much power should I make?
about ready to finish up my little project. wondering how much power you all think it should make.
truck is a 2000 Silverado 1500 z71 ecsb.
performance mods are-
2003 LQ4 swap
tsp220 cam .112 lsa
PAC springs
hardened push rods
LS2 timing set
Ported LS6 oil pump
ASP underdrive crank pulley
ASP overdrive alternator pulley
05+ oem fans/34" radiator
stock 317 heads
stock truck intake
ported 78mm tb
spectre intake
CalSpeed longtubes
single 3" exhaust
yank tt3000
vette servo
trucool 40k
tuned with hp tuners
what do you guys think? any last minute things I need to buy that's on the low budget side? the truck will be on 265/70/17 street tires for dyno. my last setup was a 5.3 with the above cam and headers. it made 268 to the tire on HEAVY 33" Toyo mud terrains. I'm hoping for 350 to the stock tire on this go around. reasonable?
2003 LQ4 swap
tsp220 cam .112 lsa
PAC springs
hardened push rods
LS2 timing set
Ported LS6 oil pump
stock 317 heads
stock truck intake
ported 78mm tb
spectre intake
CalSpeed longtubes
single 3" exhaust
yank tt3000
vette servo
trucool 40k
Should have a very similar powerband to this dyno, numbers don't mean anything really because they can very from dyno to dyno. Track times is where its @...
I did notice you haven't listed injectors. You are going to want to upgrade those...
https://www.performancetrucks.net/fo...-graph-519133/
36# Flex-Fuel injectors will do the job but they are not a direct swap.
I would look for a set of 8.1L Marine injectors from the classifieds. They are 42# and a direct swap. Overkill for your setup but you have room to grow!
TimDave217
Aug 24, 2015 04:38 PM
lxcoupe
Jul 21, 2015 02:12 AM
