how much nitrous line?
Old Feb 25, 2005 | 10:34 PM
goshawk23's Avatar
Truck addict
Default how much nitrous line?
I am needing to get a nitrous line from the bottle to the engine bay. Best i can figure coming from the back seat (extended cab) i am going to need about 14 feet and that is being way generous. I actually measured 12 feet. Should i get more or can i get away with less? This is one of those things you hate to buy too little of cause of the cost. Also, anyone know a good place to buy all my lines at?
Old Feb 25, 2005 | 10:41 PM
BigTex's Avatar
14' would be good.
I ran my line from the passenger wheel well area down to the frame and under. If you look under the floor pan of the passengers seat, you'll see a little knock out plate. I poked out the cover and ran the line in there under the carpet. It easily routed under the passenders side plastic door sill / carpet cover all the way to the back seat where it exited under the seat. Hope that made sense. No drilling or cutting and it took all of 15 minutes.
Old Feb 25, 2005 | 10:52 PM
goshawk23's Avatar
Truck addict
Originally Posted by BigTex
14' would be good.
yea that made perfect sense to me. Now what other lengths did you use for your noids to the nozzle and from the fuel rail to the fuel noid? i am thinking 1 footers but i dont' know and i know it depends on where you mount everything at. I found a guy that has some lines that is willing to give me a good deal. I just need to know what to tell him.
Old Feb 25, 2005 | 10:57 PM
BigTex's Avatar
You hit the answer - it depends on where you mount everything. You really need to do a rough mount of your solenoids and then you'll know. I mounted my fuel right to a fuel rail mounting bolt, which hit the solenoid under the facotry engine cover. 1 foot would be tight since its hard to make that line bend. I'd say 2 feet.
You could use hard lines from teh solenoid to the nozzle. I watched a friend make his lines and it turned out nice. He doesn't have any skills either.
Old Feb 25, 2005 | 11:04 PM
goshawk23's Avatar
Truck addict
haha, ok thanks man. that gives me some ideas. like i said, i want to ask before i buy and then end up looking at stuff on my garage floor like ole slowverado.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
simman22
Jan 21, 2017 10:27 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Sep 25, 2015 12:36 PM
gavin2005
Sep 13, 2015 09:04 PM
