how much meat is there to the 5.3l
Old Feb 6, 2003 | 11:13 PM
GMC SKI's Avatar
Default how much meat is there to the 5.3l
I was wondering how much meat there is to the 5.3l block i been thinking about doing some forged lower compression pistons and Cranking up the boost
Think it would be worth it in the end instead doing a 6l swap ..trying to do things cheap
I see that Y2khawk is making 700+ horsepower on a 348ci almost stock block
The 5.3 being iron would take lots of boost?
of course assuming i use ARP bolts everywhere.
think it's a good idea ?
jim
<small>[ February 06, 2003, 11:15 PM: Message edited by: GMC SKI ]</small>
Old Feb 6, 2003 | 11:20 PM
Texas Terminator's Avatar
11 Second Club
Default Re: how much meat is there to the 5.3l
give sloverado a shout, he is wanting to get my old 4.8 block and punch it out. besides, it's not the block that is the problem, it's the crap pistons and rods.
Old Feb 7, 2003 | 04:13 PM
sleepersilverado's Avatar
getting dished pistons to fit a stock bore 5.3 cost lots. it is a non common bore size so i ended up paying 960$ for a custom set of je dished pistons <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> if i did it again i would get a 6l block or something and bore it to fit 5.7 pistons because they are easy to get and cheeper because they are more common. just my thoughts
Old Feb 7, 2003 | 05:10 PM
XLR8NSS's Avatar
Adkoonerstrator
Nick Agostino from ARE has said that the 5.3L block can be taken out to around 3.9"(.120" over). That way you could use a piston made for the LS1 motors in it. Diamond Pistons may have an "off the shelf" LS1 boost piston that would work. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Just make sure you check the available piston sizes before you bore the block.
John
SS94S10
Jan 3, 2019 01:57 PM
zblee
Nov 11, 2015 12:41 AM
lxcoupe
Oct 4, 2015 08:07 PM
old motorhead
Sep 29, 2015 08:22 PM
