How much injector will I need?
Old Jun 7, 2004 | 02:26 PM
14 Second Truck Club
Default How much injector will I need?
LS1 swap, Stage 2 TEA 5.3 heads & FMS 224/224-112LSA Cam.
I want to use the LS6 intake. Will my truck fuel rails fit with this?
Thanks.
Old Jun 7, 2004 | 04:59 PM
CARAZYCUTER 4.8's Avatar
Thanks.
You are still going down no matter what you do! I am ready for a rematch. I just reformatted my timing tables & it made a big difference. Just do not bring your girlfriend so she does not see you cry! I believe you will have to by some bushings for the proper injector offset. RICHARDS GOING DOWN!
Old Jun 9, 2004 | 01:01 AM
would the 8.1 truck injectors be enough for this?
Blake: You might be making around 290-295 on the dyno as far as peak #s go after thursday, BUT under the curve is were the real power is at Like my 5.3 After I get my LS1 built I plan hitting 13s on motor (with slicks). Who knows, with the 125-150 wet shot of nitrous, I plan on outrunning a particular Blown/Cammed/Stalled Black Silverado SS....
Old Jun 9, 2004 | 10:19 AM
BigKID's Avatar
30 pounders should be more than adaquate for that as long as you dont use a dry shot.
Old Jun 9, 2004 | 03:42 PM
Thanks BigKID! Aren't you working on something big for your truck?
Old Jun 10, 2004 | 08:13 AM
BigKID's Avatar
Yea, I am working on a set of heads right now. I am doing a good cleanup job on them myself then I am going to have them milled .030. When they are done I will be putting them in along with the FMS 214/216 cam I have, new pushrods and a set of 42# injectors. The new injectors should allow me to up my dry shot a little as long as I dont max out my fuel pump or maf. Since my install is still about three weeks out, I may go ahead and get a new fuel pump and go ahead and do it at the same time.
Old Jun 10, 2004 | 09:07 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
What if you do use a dry shot?
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
