How much hp with 43 lb inj.
Old Jan 20, 2005 | 10:01 AM
quicksilverado's Avatar
Default How much hp with 43 lb inj.
How much rwhp will 43 lb injectors support?
Old Jan 20, 2005 | 12:36 PM
BigTex's Avatar
Should be 500+ rwhp with a power adder and more N/A.
Old Jan 20, 2005 | 09:43 PM
driftpin's Avatar
Sorry to go a little off topic here but if I picked up a set of 30# injectors and had my MAF remapped for the injectors, do you think I would pick up any HP/TRQ? or would it just be a waste of fuel?
Old Jan 20, 2005 | 09:46 PM
BlownChevy's Avatar
blownerator
25 Year Member
Old Jan 20, 2005 | 10:40 PM
sfj
prolly wont see to much increase in hp and tq because you dont haver the mods for it but will help much with the later mods
Old Jan 20, 2005 | 10:50 PM
driftpin's Avatar
I plan on picking up a Dynatech header and cat from Jegs next month and I'm still trying to figure out which catback to go with. Other than that, what mods would you think would be best? I was looking at that Vinci "44" Cam (210/218 .531/.531 114) and supporting mods.
Old Jan 20, 2005 | 10:53 PM
XLR8NSS's Avatar
Adkoonerstrator
Just curious. Why did you have your MAF remapped and not just get the Injector Flow Rate changed to the appropriate setting instead? I'm assuming custom tuning was involved but, if a MAFT was used I understand.
As long as your tune(A/F ratio) is the same you shouldn't see any increase from the injectors. If you rescaled the MAF then it might mess with your timing a little bit, there could be an increase from that if your timing changed some.
Old Jan 20, 2005 | 10:56 PM
driftpin's Avatar
No, you misunderstood me, I haven't had this work done. I am just looking for some HP/TRQ and was throwing around some ideas.
Old Jan 20, 2005 | 11:03 PM
XLR8NSS's Avatar
Adkoonerstrator
Oops, I see now you said "if I picked up a set".
They wouldn't hurt to have with the mods you're picking up but, if you do get them just change the Injector Flow Rate to compensate. Don't mess with the MAF to tune the injectors.
GONEB4U
Aug 27, 2012 08:12 PM
GONEB4U
Apr 2, 2012 08:18 PM
KBOBOZ71
Jan 19, 2007 09:16 PM
