How much have you gained at the track with nitrous?
Old Jan 27, 2004 | 10:42 PM
14 Second Truck Club
Default How much have you gained at the track with nitrous?
Just wondering how much everyone's times have improved with nitrous. Please tell us your before/after times and how big of a shot you are running.
Old Jan 27, 2004 | 10:52 PM
BigTex's Avatar
My old Z71 gained over 1.5 seconds. Maybe closer to 2 seconds. That was on a max of a 125 shot.
I should add that the 60' time decrease was a big factor in the lower ETs. From low 2.2s to 1.7s.
Old Jan 28, 2004 | 12:07 AM
Grey Silver's Avatar
11 Second Club
I picked up a second w/ a stock 5.3 and a 100 shot on street tires.
Old Jan 28, 2004 | 02:25 PM
BigKID's Avatar
With a 100 dry shot, I have gained up to 1.2 sec. Last trip to the track I only gained .9 sec because of traction problems. Was running 13.8x on motor and 12.9x on the spray with the same 60' on both.
Old Jan 28, 2004 | 02:46 PM
O3GMC's Avatar
12 Second Club
So could I expect about a half a second with a 50 shot? I will find out one of these days if I can ever get a good deal on some tires.
Old Jan 28, 2004 | 04:40 PM
parish8's Avatar
single digit dreamer
seems like i got 2.5sec on my truck when it was stock other than the nx kit, that was with the 4.8 and a 100shot right out of the hole. seems like a 15.9 down to a 13.4
if you spray out of the hole and can hook you will get more than .5 with a 50shot i bet but if you can't hook who knows.
Old Jan 28, 2004 | 09:30 PM
GoldenVelvet's Avatar
With a 60 dry shot I was able to drop just shy of a sec. I went from a 15.2 to a 14.3. The 60' went from a 2.3 to a 2.3 (dam that traction) Im hopping to hit the 13's with a 120 dry shot and 4.10's. And 12's with traction and a BIG propane powered wet shot until the motor dies its nitrous filled death.
Old Jan 28, 2004 | 09:42 PM
So, if I was to get a 75-100 shot along with P&P heads w/ LS1 valves, milled .020 and a 2400 stall, and bigger gears, could I get low-mid 13s?
Old Jan 28, 2004 | 11:33 PM
BigKID's Avatar
That should put you in the 12s with traction.
Old Jan 29, 2004 | 01:33 PM
redaddiction's Avatar
What pills are you using for a 125 shot on a stock 6.0 ?
