How much do our motors weigh?
Originally Posted by bmbutler
Does anyone know what one of our long blocks (4.8 / 5.3) would weigh from intake to oil pan?
I would also like to know the weight of the aluminum 5.7
What about getting 4 scales with wood and blocks on 'em and then placing the engine on the wood. 4 scales rated to 200lbs each should be able to handle the heft. add all the weight up minus the supporting material and voila!
Do not know the weight of the engines, but seems I read somewhere that the aluminum blocks are about 100lbs. lighter than the iron blocks. Go to one of the websites that sell engines and see what the shipping weight is on one.
It wouldn't really concern me if it were in the back of the truck, but the front is the worst place to have weight. Oh well.
A hundred pounds off the front sure would be nice.
Take a look at the dyno and the forced induction sections. Alot of guys are putting down some impressive #s with aluminum blocks. For outrageous #s they are using iron blocks, but 450-550 rwhp is enough to make me happy. A 5.7 aluminum block with a few bolt ons and a turbo would put you in the 500 range. It would also be a good daily driver. If you wanted more power simply turn up the boost.
I don't know about our engines in particular, but a small block chevy with iron block and heads and an aluminum intake, with water pump weighs about 500lbs. Aluminum heads can take off as much as 40lbs. So I'd say the 4.8/5.3's weigh close to 450lbs...with the LS1's weighing about 350lbs.
No,no, no...if you see that some one has left one lying around. Don't hurt yourself, let me know and I'll come help you out.
Oh yeah, I seem to remember that Ford all iron small blocks only weigh about 425. So with an Al block/heads I can see 350 being possible.
lxcoupe
13
Nov 20, 2015 08:43 PM
