How much boost is the Radix good for?
Old Apr 11, 2005 | 11:58 PM
thunder550's Avatar
High on diesel fumes
Default How much boost is the Radix good for?
What is the smallest pulley available for the Radix, and what is the corresponding boost? I'm starting to put together a plan for my new setup.
Old Apr 12, 2005 | 12:00 AM
moregrip's Avatar
what a rush!
boost depends on many many things. smallest pulley available 2.75".
Old Apr 12, 2005 | 01:52 AM
thunder550's Avatar
Then I'll describe what I'm aiming for. I want to put in an LQ4 block with a mild cam designed for FI, and heads that will maximize compression based on how much boost the Radix will put out. I figured that getting a number for psi would allow me to start looking at what kind of heads to buy. Shooting for ~650hp flywheel.
Old Apr 12, 2005 | 02:27 AM
moregrip's Avatar
what a rush!
LQ4 with stock 72cc Heads and stock 9.4-1 compression ratio and the radix with a 2.8" pulley = about 10 lbs of boost ala BlownChevy.
Old Apr 12, 2005 | 08:58 AM
thunder550's Avatar
Is that about the most you can stuff in there without detonation or is there room for a little bit more?
Old Apr 12, 2005 | 12:37 PM
8ALTNG's Avatar
At one point I was making 12lbs with a 3.25 pulley
Old Apr 12, 2005 | 02:50 PM
thunder550's Avatar
did you weld something over the intake ports or what??
Old Apr 12, 2005 | 05:28 PM
moregrip's Avatar
what a rush!
I suppose it would depend on a few things but I'd be willing to bet you could get a little more.
Old Apr 12, 2005 | 05:30 PM
BlownChevy's Avatar
blownerator
25 Year Member
That was on a 4.8L
Old Apr 12, 2005 | 05:54 PM
Flyer's Avatar
Excessive boost isn't needed. Build the motor to be effecient and it will run good. Of course, more boost is usually better, but not always.
On a 6.0 I would shoot for ~9:1 CR and go from there.
