How much boost can be run on a 6.0 with a radix?
Old Dec 11, 2003 | 09:07 PM
14 Second Truck Club
Default How much boost can be run on a 6.0 with a radix?
Just Wondering. With the pullies available for the radix, how much boost would the smallest one put out on a 6.0 with the following:
-Long-tube headers w/free-flowing dual exhaust
-Electric Fans
-02' LS6 Cam or other blower friendly cam
-Custom Dyno-Tuning
-2600 stall
-3.73 gears
-slicks
-other "little things"- Ported TB, Free Mods, Descreened MAf, etc.
Also, How much power would this truck make at the wheels (HP & TQ)? What would it run at the track (assuming it was a single-cab step-side)?
Would be a pretty cool truck huh?
Old Dec 11, 2003 | 09:23 PM
MNC5's Avatar
Originally Posted by 99silveradoSS
Just Wondering. With the pullies available for the radix, how much boost would the smallest one put out on a 6.0?
A 2.75 is about the smallest you'll be able to run without belt slippage being an issue.
A stock 6.0 with a 2.75 should be around 10-11 lbs of boost.
Old Dec 11, 2003 | 09:31 PM
You would probably see detonation pushing that much boost. If it was my truck, I would throw an alcohol injection on it to eliminate the detonation.
Old Dec 12, 2003 | 04:12 PM
tbyrne's Avatar
The smallest most people go with is the 3" pulley. This will give you another 3# of boost. You'll loose a little with the long tubes and free flowing exhaust so you should see about 8.5-9#. I'd be worried about detonation with anything more than this. I also consider 9# to be the safe limit but some people have run more than this on a stock motor with no problems.
Tom
Old Dec 12, 2003 | 04:25 PM
ACDenali's Avatar
I am considering an aftermarket cam in my 02 Denali. Trying to decide on which to go with.
Old Dec 12, 2003 | 06:37 PM
BlownChevy's Avatar
blownerator
25 Year Member
3.0 would be the limit without tuning. There are also upgraded heat exchangers coming soon!
Old Dec 12, 2003 | 09:49 PM
slimsoftball's Avatar
I run the 3.0 pulley on my Magnacharged Silverado SS. My gauge shows just a hair over 8 lbs. I have had no problems as of yet.
Old Dec 12, 2003 | 10:38 PM
BlownChevy's Avatar
blownerator
25 Year Member
There you have it folks!!!
Old Dec 12, 2003 | 11:25 PM
FarmTruc's Avatar
Performance Trucks Sponsor
The 3" will work just fine. Before tuning, there was no detection of detonation, so no tuning is required.
I think you could get away with one size smaller and tuning, wonder how that would turn out, hmmm.
good luck,
allen
Old Dec 12, 2003 | 11:29 PM
BlownChevy's Avatar
blownerator
25 Year Member
good luck,
allen
Smaller pulley = more boost! Now thats what I am talkin' about!
