How Much Boost?
Old Apr 21, 2004 | 06:29 PM
Boosted 6.0's Avatar
Default How Much Boost?
How much boost / what size pulley can I safely run without modding my engine? It's a stock LQ4 with a Radix.
Old Apr 21, 2004 | 06:59 PM
BlownChevy's Avatar
blownerator
25 Year Member
I am running a 2.8 pulley making 9.5 psi on pump gas.....
What all is done to the motor?
Old Apr 21, 2004 | 07:20 PM
i have heard that 2.9 is as high as you should go on the LQ9
Old Apr 21, 2004 | 08:31 PM
BlownChevy's Avatar
blownerator
25 Year Member
This is true....the LQ9 is a higher compression motor.
Old Apr 21, 2004 | 09:47 PM
F8L Z71's Avatar
Why not wire up an alcohol injection kit and go higher??
I see a ton of people that are limiting themselves because of air temps coming from the blower when they can easily add a meth kit and run at least 3+lbs more boost.
I am having a kit custom designed for my truck and it is only around $500.
Old Apr 21, 2004 | 09:51 PM
moregrip's Avatar
what a rush!
does that mean the LQ4 has potential for more?
Old Apr 21, 2004 | 09:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
Yes and no.....There is potential there, but not for more boost!
Old Apr 21, 2004 | 10:01 PM
moregrip's Avatar
what a rush!
hmmm, you have my attention.....
Old Apr 21, 2004 | 10:17 PM
I have stock internals and tuning by Lyndon, I don't want to do too much because I want to keep the warranty. I'm having a stealth stall installed and a shift kit, but I've refrained from headers and cam because I'm pretty sure it'll void my 5 yr powertrain warranty. The dealer is cool with the blower. I have a 3.1 pulley, I figure boost and tuning is pretty cheap. I'm looking to Brian for a good deal on a pulley. And then save some $$$ for a rebuild.
How much boost would I would be running with a 2.8???
Old Apr 21, 2004 | 10:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
With the 2.8 I see 9.5 PSI. The only problem is these pulleys are hard to find
