how many rpms are you turning
Old Mar 21, 2004 | 12:19 PM
4.8bowtie's Avatar
Default how many rpms are you turning
on stock internals how many revs is safe.governor is set at 6200 is it ok to turn 6200.only push it to about 5800 now but it still pulls dont want to
Old Mar 21, 2004 | 12:59 PM
the bottom end in these things is almost bulletproof. Im spraying mine with a 225hp shot and shifting a little over 6300rpms and no problems yet. Ive herd of some guys with just cams running @6800rpms. Wow, you have a 5spd Z71. I didnt know they had those. You ever tried launching it in 4hi very hard? Ive always wondered how much those trannys could take.
Old Mar 21, 2004 | 04:20 PM
4.8bowtie's Avatar
never tried it im afraid to bust something i dont think the tranny or transfer case would take it.with 20k and some hard launches the tranny still like new but wouldnt dare try it in 4hi
Old Mar 21, 2004 | 04:37 PM
I dont know much about the trannys they put in your truck, but i know that the ones they had a few years back were made by Muncie. If the one in your truck was made by Muncie too, id say the thing is tough as hell. My engine has almost 60k on it and ALOT of trips to the track. Its never missed a lick. The bottom ends are 6-bolt mains! It can take the rpms no prob IMO. If your doing high rpm shifts and launches you may want to look into a better clamping clutch.
Old Mar 21, 2004 | 04:59 PM
Flyer's Avatar
I'm spinning it up to 6300 with 7 pounds of boost.
Parush is spinning his up to 6800, but he did replace the rod bolts with some better ones.
Old Mar 21, 2004 | 05:23 PM
Black02Z71's Avatar
I wouldn't be worried about the bottom end, floating the valves is what I worry about. When I got a tune for my predator I asked to have the rev limiter set to 6300, they set it to 6550, so they must think its safe to run that high, I shift at 6000 with the cam. another question is will the tranny hold up at that high an rpm.
Old Mar 21, 2004 | 07:57 PM
Flyer's Avatar
Just like you said ... valve float is what you need to worry about. If you have the LS6 springs or somehting better, then you will be safe up to about 6800 with a low lift cam.
Old Mar 21, 2004 | 11:07 PM
parish8's Avatar
single digit dreamer
i know you said stock but i have springs and rod bolts and take it to 6800. i have heard 6800 with just springs is realativly safe.
Old Mar 21, 2004 | 11:21 PM
With a stock bottom end, I shift mine at 6700. I would shift alittle higher, but my rev limiter is set at 6800.
Old Mar 22, 2004 | 01:50 AM
The trannies are made by new venture gear, they arent the strongest trannies out there but they are ok. I dont know how long it would last but i dont think you need to worry about the t-case.
I shift at like 5800 right now but thats gonna change to about 6300 soon
Choda
Jun 5, 2025 06:43 PM
MOBBN
Sep 11, 2015 08:34 PM
b4z
Sep 10, 2015 06:58 PM
Boyes50
Sep 8, 2015 12:06 PM
