How many cc per .01 milled
Old Feb 21, 2010 | 11:16 PM
pewterliftedz's Avatar
Default How many cc per .01 milled
like the title says.
i was thinking about it today, on 317s how many ccs are taken off with every .010" milled..
my plans were LQ4 and 862 heads with 2.00" valves and ported, that would yield me around 10.5:1 compression..
can a similar compression be obtained with 317s, they already flow better and have 2.00" valves..
any info would be awesome guys..
Old Feb 22, 2010 | 11:34 PM
bump...
Old Feb 23, 2010 | 12:00 AM
La Tu Papi's Avatar
Banned
5.3 heads on a lq4 is around 10.8
for .03 off the heads that is around 7 cc
317s milled that much will net you same results as installing 243s on a LQ4 which would be 10.4
Old Feb 23, 2010 | 12:13 AM
fastgmc53's Avatar
14 Second Truck Club
best info for us...
https://www.performancetrucks.net/fo...6&postcount=17
Old Apr 27, 2010 | 09:54 AM
How much meat can be milled from the head before you have head to intake sealing problems?
Old Apr 27, 2010 | 09:55 AM
Mangled03gmc's Avatar
Baltimore Whore
The max you can go is about 40 before you start running into intake issues
Old Apr 27, 2010 | 10:12 AM
Thanks i was really wondering about that when I change my cam out. I want to mill the heads because they are a 72 cc and the motor was built for FI but i went NA instead so a boost in compression should help a little.
zblee
Nov 11, 2015 12:41 AM
someotherguy
Oct 5, 2015 12:49 PM
gmcyukon
Oct 3, 2015 11:03 PM
old motorhead
Sep 29, 2015 08:22 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
