how long would you drive to change your 918's
I just got my replacement 918's and they look pretty. I am gathering parts to do a Head swap. Would you drive 3 hours to my tuner/mechanic and put the springs on the new heads and do the head swap or should I swap them then drive out and switch them then?? It's a PITA to do them on the truck in the snow, and would be so much easier to put them on the new heads on the bench.
thanks
thanks
I dont want to drop a valve. I am not comfortable swapping the heads and if I did I would need to get the tune right, so I want to get my truck to the tuner. Its a few hours drive and I still have the old 918's on the motor, should I worry and change them now (which I have done before) and drive out. Then swap them @ his place.
sorry for being confusing
The old 919's are just fine. Yeah, there were some problems but it wasn't a global issue. If you have been running them for a while you should be fine. Of course it is totally up to you.
ARC
57
Feb 21, 2022 10:54 AM
walledition
Jul 29, 2015 08:54 PM
atxlt
Jul 20, 2015 11:06 PM
