How lean is to lean? Plus dyno run on STS.
Old Nov 1, 2005 | 01:04 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I got mine dyno tuned with a wide band for $250 bucks. 6-700 seems way high. Of course mine blew up a week later, , just kidding John (Tuner) Just make sure you have big enough injectors and pump capacity to feed them. But the price sounds high on the tune, shop around.
Old Nov 1, 2005 | 02:04 PM
zippy's Avatar
under wide open the computer isn't going to pull fuel from a rich condition. you simply don't have enough injector. you're going to need at least 30's. i'd recomend stepping up to a 42 though.
Old Nov 1, 2005 | 02:40 PM
TurboAv's Avatar
Yeah I am going to go with the delphi 42's and a walbro pump. Then more boost!
Old Nov 1, 2005 | 02:57 PM
ktmrider's Avatar
Originally Posted by Yellowsierra
I think I know what your problem is. When your meth. comes on its telling your o2's your running really rich so it backs off your fuel supply. Your o2 will read 900mv but meth reads alot higher than fuel so your cpu thanks your at the right a fuel ratio while your really running way lean. The only way to get it tuned right is to use a wideband or at the dyno. Oh yeah you also need some 42 lb. injectors
I agree. Also remember that you will run 0.5-1.0 points A/F leaner on the street than on the dyno ( unless using Mustang load style ). Your computer is calibrated to run at 14.7:1 A/F under N/A conditions and is tuning out the benefits of the meth.
Get rid of the stoic 14:1 and go with the bigger injectors, pump, and custom tune. Your engine and pistons will live/love you for it!
Old Nov 1, 2005 | 04:33 PM
zippy's Avatar
if he's programmed properly as soon as boost comes on he'd be in P.E. mode so that the computer can't compensate for the meth.
Old Nov 1, 2005 | 05:19 PM
O3GMC's Avatar
12 Second Club
Originally Posted by TurboAv
I guess my Predator will turn into an overpriced code reader.
Join the Predator=code reader club
stealthperf
34
Feb 14, 2016 11:35 AM
rednekferlife101
32
Jan 8, 2016 10:42 PM
05GMC4.8
Aug 7, 2015 09:55 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
signguy62
Jul 16, 2015 05:43 PM
