How lean is to lean? Plus dyno run on STS.
I got mine dyno tuned with a wide band for $250 bucks. 6-700 seems way high. Of course mine blew up a week later,
, just kidding John (Tuner) Just make sure you have big enough injectors and pump capacity to feed them. But the price sounds high on the tune, shop around.
Originally Posted by Yellowsierra
I think I know what your problem is. When your meth. comes on its telling your o2's your running really rich so it backs off your fuel supply. Your o2 will read 900mv but meth reads alot higher than fuel so your cpu thanks your at the right a fuel ratio while your really running way lean. The only way to get it tuned right is to use a wideband or at the dyno. Oh yeah you also need some 42 lb. injectors
Get rid of the stoic 14:1 and go with the bigger injectors, pump, and custom tune. Your engine and pistons will live/love you for it!
Originally Posted by ktmrider
I agree. Also remember that you will run 0.5-1.0 points A/F leaner on the street than on the dyno ( unless using Mustang load style ). Your computer is calibrated to run at 14.7:1 A/F under N/A conditions and is tuning out the benefits of the meth.
if he's programmed properly as soon as boost comes on he'd be in P.E. mode so that the computer can't compensate for the meth.
05GMC4.8
Aug 7, 2015 09:55 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
