how to install new injectors-GMCSKI help?
My new Saturated Delphi Mini injectors-SDM 370 will be here in a day or so.Any tips on installing them?
They are the same ones as GMCSKI has. He mentioned to watch out on the first start, before the PCM learns to run with them, as you can easily flood the motor.
Should I put in the modified injector flow rate table first, or after the PCM learns to run them?
Should my first start be a clear flood method?
Any other tips on putting them in? I don't want to mess these up, they are very exspensive.
Thanks for any help! Sam
not sure if the profile works, so - 2000 4WD Ext cab 5.3 ATI P-1SC, LS1Edit, stock manifolds, single 3" bullet exhaust
Sam, if you have LS1 edit, go ahead and program the PCM before you start it. I went from a 99 21 pound injector to a SVO 36 pound injector with no problems.
LCHEE
Oct 24, 2020 04:10 PM
GXPJAY
Nov 5, 2015 06:49 AM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
