How to get compression up on LQ4
Old Nov 27, 2007 | 10:29 PM
hirdlej's Avatar
Originally Posted by Rhino79
Mill the heads about .040" and run a thinner gasket.
How thin of a gasket will I need then? If I mille .040 and go with we'll say a .020 gasket, what will it be at?
Old Nov 27, 2007 | 10:44 PM
Rhino79's Avatar
9 Second Club
Mill .040 and run a .040" gasket and you should be 10.5-10.6 cr.
Old Nov 28, 2007 | 07:06 AM
joshua022's Avatar
Will this work in my situation also??
putting 243s on a 5.3??
How thick is the stock replacement gasket??
Old Nov 28, 2007 | 07:26 AM
Rhino79's Avatar
9 Second Club
Yep, but you wil be closer to 10:1 because the stock 5.3 heads have small chambers to begin with (61 I believe). The LS6 chmabers are 64-65 so You would not gain as much compression as the 6.0l guys. Now you can mill your 5.3 heads .040" and run a .040" gasket, and you would be somewhere around 10.5. The stock gasket is about .054".
Old Nov 28, 2007 | 09:10 AM
joshua022's Avatar
Where or who could I get a .040 gasket from for a 5.3??
Old Nov 28, 2007 | 06:37 PM
Rhino79's Avatar
9 Second Club
Not sure, but Cometic may make one, Fel-pro may as well.
Old Nov 28, 2007 | 08:05 PM
67SS509's Avatar
10 Second Truck Club
You might want to check and see how much the pistons are sticking up out of the hole. All the LQ4's and LQ9's I have worked on were .008" to .012" up. You would not want a head gasket too thin, .035" quench is the minium I would suggest.
piston up measurement + .035" minium quench= head gasket thickness
Velocity1
Oct 2, 2015 08:01 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
old motorhead
Sep 29, 2015 08:22 PM
Slammed silverado
Sep 28, 2015 06:14 PM
