How to find/buy nuts and bolts?
Old Jun 7, 2007 | 02:37 PM
thehemi's Avatar
Default How to find/buy nuts and bolts?
Ok, as I work on my V8 S10 swap some more, I'm going
to need some random nuts and bolts. For example, I'm
going to need bolts for a flywheel and alternator (so far).
What's the best way to go about finding and buying them?
Thanks!
Old Jun 7, 2007 | 07:01 PM
COLDZ71's Avatar
You can get them from ARP. You can order them through Summit or Jegs.
Old Jun 8, 2007 | 01:54 AM
CashDudeHomie's Avatar
If it's not a real important bolt, i'll just use a grade 8 from the hardware store. For critical engine parts, ARP are best.
Old Jun 8, 2007 | 08:02 AM
thehemi's Avatar
I'm doing a V8 swap into an S10, so I'm going to need
a bunch of nuts and bolts that I don't have. Most are
going to be non-important bolts. The trick, I guess, is
figuring out the sizes of the bolts required...
PartsLand.com is an awesome site I use for jetski parts.
Exploded part breakdowns and P/Ns for everything. That
is what I was hoping was available for GM trucks...
Old Jun 12, 2007 | 08:24 AM
thehemi's Avatar
Seriously there's no other easy choice for random nuts and bolts?
If I'm bolting in a P/S pump and need the bolts, I need to order an
ARP set (if they're even available) or go visit my area stealership?
Old Jun 12, 2007 | 09:42 AM
brentg454's Avatar
https://ls1tech.com/forums/showthread.php?t=265717
In the Conversions & Hybrids section of LS1Tech there is a sticky with all the GM P/N's for accessory drive parts (including bolts), although I would recommend just figuring out what size bolt you need and getting them from a hardware store (much less expensive).
For what it's worth, all the front accessories use the same bolt threads. I can't remember the size off the top of my head, but they all have a 15mm head. I think it is M10 x 1.5, but don't quote me on that.
I just noticed this weekend that the flexplate-to-converter bolts are the same, too.
mikeyjm1
17
Oct 29, 2015 11:04 PM
Justin87gn
Sep 10, 2015 12:06 PM
MA$TER_E
Sep 9, 2015 03:14 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
