how to drain radiator fluid on a 2004??
my wifes cc, overheated yesteday and dont know why... I just changed the thermostat on it and it was still overheating, then after a while and ran good?? drove it this a.m. and looks like its doing good so I hope that was the problem but anyways.... when I installed the new thermostat I refilled it with just water just incase it was something els and I would have to drain it again... seems like its working fine now and I want to refill it with antifreeze but I cant find a drain plug?? its not where my 2001 has it??
do any of yall absolutely hate those black clip on hose clamps, where u gotta squeeze the clip, and slide it off, i tried replacing my thermostat, i say try, because for some reason, i ordered the ls1 thermostat from texas speed, and it didnt fit, after i drained the coolant out, pulled the old thermostat, and realized that, hey..... this doesnt fit! turns out i had a different pump on my 04, texas speed said it was a ls2 style pump. So.... im fixing that issue, but... back to those clamps, i absolutely hate those clips, because from constant pressure and temperature, its hell to get them things off, im a mechanic and i still cringe when i see those. So when i do a replacement on a hose, i use handy dandy screw clamps.
just my 2 cents
jared
just my 2 cents
jared
but yah, undo the bottom hose, and try to not make a big mess when u do it, if i remember correctly, theres a few things in the way that like to make ur coolants flow direction splatter everywhere.
just my 2 cents
jared
just my 2 cents
jared
just my 2 cents
jared
just my 2 cents
jared
i was using the "fix all" vice grips, funny how many things u can fix with vice grips, lacing wire, a hammer, some zip ties and silicone lol, i need to get some hose clamp pliers, i didnt think they had a special tool for them, maybe that will save me on beer and ciggs
GM got cheap and saved a ton on that one. There is no easy way to do it without making a mess. Just pull the lower hose.
