How do you like your LS6 intake?
Old Nov 7, 2007 | 10:05 AM
  #21
99/5.3w/hips's Avatar
Originally Posted by adam1803
Im using truck injectors and fuel rail. I just removed the pintle caps and used different o-rings. The crossover tube on the rails sits a little high and you've got to make brackets to mount the rail but its not hard.
and im doing sort of the opposite. Im running car style injectors in my stock truck fuel rails and manifold. I will be swapping to LS6 though soon, I will just fab up some brackets so I don't have to swap fuel rails
Old Nov 7, 2007 | 04:14 PM
  #22
Phantom's Avatar
11 Second Club
Originally Posted by OnyxSilveradoSS
I thought for DBW you needed a throttle spacer to put the TB out a little further.
you still have to modify the waterpump neck to clear...just buy an ls1 water pump with the snout sticking straight out and be done with it
Old Nov 7, 2007 | 04:58 PM
  #23
TXsilverado's Avatar
just to make sure im reading right....this new l92 water pump makes it to where you dont have to relocate the idle pulley on cable trucks??? just install the intake, belt and necessary fueling and its done!
no home fabbing up idle pulley brackets? thats awesome if so.
Old Nov 7, 2007 | 05:16 PM
  #24
regency's Avatar
if thats the case then you will need 2 of them!!!! DBW is a huge unit, it might work on the DBC. (the spacers that is)!!!!!!!!!!!!!!!!!! yea you can use the new pump on the DBC but not on the DBW which SUCKS
Old Nov 7, 2007 | 05:22 PM
  #25
maybe ill be doing the ls6 swap after the heads and n20
Old Nov 7, 2007 | 05:26 PM
  #26
regency's Avatar
for sure i would be doing it soon to compliment those heads and cam. I'll have a speartech style bracket for sale in a month or two if anyone is interested in waiting
Old Nov 7, 2007 | 06:06 PM
  #27
fossil's Avatar
11 Second Club
I tried the L92 water pump with the L76 intake and my cable controlled throttle body would not clear the water pump neck, not even with grinding. I had to use a Vette ls2 water pump.
Old Nov 7, 2007 | 07:04 PM
  #28
regency's Avatar
thats because that throttlebody is actually bigger
Old Nov 7, 2007 | 08:21 PM
  #29
you will still need to relocate the idler pulley, it's in the way
Old Nov 7, 2007 | 08:34 PM
  #30
crap im not in the mood to do it again then haha. why not just twist the factory neck to the side like alot of other guys do without any problems?
