How do you like your LS6 intake?
Old Oct 14, 2007 | 06:41 PM
colekill's Avatar
KickinAssAndTakinNames
Default How do you like your LS6 intake?
I know it looks good but did you see a HP gain?
is it worth the 400+ dollars?
Old Oct 14, 2007 | 06:49 PM
dirt track racer 81's Avatar
look on ls1 tech and you can get them around 300-350..im gonna get me one payday..you have to have the fbody water pump and all the accessories and crank pulley, and you would need fuel rails that are return style for it and ls1 injectors and the bosch connectors
Old Oct 14, 2007 | 06:57 PM
kw05silverado's Avatar
so its more of a hassle than anything else..
Old Oct 14, 2007 | 06:59 PM
pretty much unless you have the mods to support it
Old Oct 14, 2007 | 07:01 PM
yea whens the best time to get the manifold? before puttin in a nice size cam?
Old Oct 14, 2007 | 07:06 PM
bluecajun5.3's Avatar
11 Second Truck Club
after
Old Oct 14, 2007 | 07:09 PM
nightrunner's Avatar
Mr. Obvious
Originally Posted by bluecajun5.3
after
after a big cam AND all your boltons
now it has become known that you can simply swap to a L92 water pump and get by without having to swap your accessories
Old Oct 14, 2007 | 07:17 PM
colekill's Avatar
thats what i heard, just the water pump. i did not know about the fule rails and injectors.
i figured the ls6 intake was next since i'm a full bolt on and a cam(mild cam 212/218) plus it looks really good
what gains would i see with the Ls6 inkake?
Old Oct 14, 2007 | 07:30 PM
v8
17,16,15,14,13,12,11 Drvr
little to none, it could even hurt your times or hp, with that baby cam stay with the truck intake. The swap could cost you any where from 500 to 1000 bucks, good luck.
Old Oct 14, 2007 | 08:22 PM
adam1803's Avatar
for a mildly modded motor, don't bother. Its not nearly as complicated as some people make it out to be, but for your application the truck manifold is sufficient.
