How do you like your LS6 intake?
Old Oct 14, 2007 | 08:41 PM
1TRUESS's Avatar
I like mine a lot so far and I have not got it tuned all the way yet! Don't know if it is the cam or intake, but it pulls damn hard running really rich up top now! It also makes my engine bay look a lot better!
This is what i did - Click Here!
Also: don't for get I have a T56 and 4.56 gears!
Old Oct 14, 2007 | 08:51 PM
xdanny510x's Avatar
so let me get this str8 just witn the l92 water pump and the manifold u dont have to change anything else? such as fuel rails etc etc? how would that manifold go wit my mods? sorry if i jacked ur thread just wanted to kno the same thing as u did bro
Old Oct 14, 2007 | 09:02 PM
nightrunner's Avatar
Mr. Obvious
id say you need to get a stall and a built trans first but yes teh intake would compliment your mods very well
no the water pump only solves the problem of the TB clearance. you still need to swap over to car style fuel rails and injectors
Old Oct 14, 2007 | 09:06 PM
xdanny510x's Avatar
i got my stall just for got to add it in my sig.. its a 3000 stall
Old Oct 14, 2007 | 09:35 PM
Quik's Avatar
5 year bitches!
3k stall will haunt you!!!!!!!!!!!! too freaking small!!!
LS6 is worth it, and as for cost. last winter i sold mine for 250. those intakes are like fruit. one month they are in season for good prices, next month they sell for nothing. I ended up catching mine in off season and couldnt get no more then 250 for mine but i guess when you get it for 50 bucks you cant complain.
Old Oct 14, 2007 | 10:41 PM
adam1803's Avatar
Im using truck injectors and fuel rail. I just removed the pintle caps and used different o-rings. The crossover tube on the rails sits a little high and you've got to make brackets to mount the rail but its not hard.
Old Oct 15, 2007 | 09:24 PM
xdanny510x's Avatar
damn my stall is that bad i thought it was great lol
Old Oct 16, 2007 | 06:53 AM
shanekennedy's Avatar
got a pic you can share?
Old Nov 7, 2007 | 07:41 AM
04BlackSilverado's Avatar
The pump swap will NOT work on any truck with drive by wire (03+). You need to modify the truck pump outlet tube or swap pullies with a car pump.
The L92 pump will fit on any LS block but will work with the LS6 intake mod for the cable driven TB's only.
I have a 6.0 with the L92/L76 intake and heads, and I have a modified car pump. works great.
Old Nov 7, 2007 | 08:45 AM
OnyxSilveradoSS's Avatar
I thought for DBW you needed a throttle spacer to put the TB out a little further.
