How do I tell if my 00' Silverado has Posi or not?
Old Aug 19, 2004 | 07:00 PM
ktmrider's Avatar
If the code is confusing the easiest way is to lift the rear axle off the ground ( safely as always ). Release the ebrake and turn one wheel. If wheels turn in the same direction, you have posi. If one turns in the opposite direction, peg leg ( old saying for regular differential ).
Thanks 6gear for the code breakdown!
Old Aug 20, 2004 | 07:18 AM
6gear's Avatar
You are right on a posi but I think the G80 Gov lock units will act like a regular differential untill you turn one tire fast enough to activate the governor
Old Aug 20, 2004 | 08:19 AM
zippy's Avatar
Originally Posted by digital
Hey thanks for the input fellas...
Another question I have is regarding the tune I'm about to get...I want to find out about eliminating Traction Control to light up 20'' wheels with a Whipple blower... what is a good/safe amount of TC to remove without hurting anything like the tranny, etc....
I guess this is a two-part question, also what shift-firmness should I be aiming for?
if your truck has the traction control option all you have to do is push the button to turn it off. as for shift firmness, i wouldn't do it with programming. i'd install a good shift kit with billet servo's.
Old Aug 20, 2004 | 11:53 AM
digital's Avatar
I'm sorry, I meant Torque management, not traction controll..
Old Aug 20, 2004 | 12:52 PM
zippy's Avatar
lol, oh ok.
Old Aug 20, 2004 | 01:16 PM
Scream's Avatar
MOOBIES Moderator
TM won't keep you from spinning your tires.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
Eddielerma
Aug 11, 2015 01:10 AM
85SS/85GN
Aug 7, 2015 04:30 PM
