How do I tell if my 00' Silverado has Posi or not?
Old Aug 18, 2004 | 09:06 PM
digital's Avatar
Default How do I tell if my 00' Silverado has Posi or not?
Is there a way I can tell if Chevy installed posi in my 00' Silverado 1500 Ext-Cab LT?
Thanks,
Old Aug 18, 2004 | 09:11 PM
6gear's Avatar
It should have a G80 code on the sticker in your glove box. It is usually followed after your gear ratio of GU4, or GU6, or GT4.
Old Aug 18, 2004 | 09:19 PM
nativetexan's Avatar
13 Second Truck Club
Nah, just power brake it and see if both are turning. More fun that way.
Old Aug 18, 2004 | 09:30 PM
digital's Avatar
Got it, there is the G80 code followed by GT4, what is GT4?
Old Aug 18, 2004 | 09:53 PM
that should be the gear ratio im not exactly sure what it is probably 3.42
Old Aug 18, 2004 | 09:56 PM
Mort's Avatar
Smile
GT4 = Rear Axle, 3.73 ratio
Old Aug 18, 2004 | 10:00 PM
budhayes3's Avatar
PT's Slowest Truck
I have the G80 code, and my window sticker lists it as a locking rear differential. Did/do these trucks come with a limited slip, or has that been replaced by the locker? Sorry about hijacking the thread.
Old Aug 18, 2004 | 10:18 PM
digital's Avatar
Hey thanks for the input fellas...
Another question I have is regarding the tune I'm about to get...I want to find out about eliminating Traction Control to light up 20'' wheels with a Whipple blower... what is a good/safe amount of TC to remove without hurting anything like the tranny, etc....
I guess this is a two-part question, also what shift-firmness should I be aiming for?
Old Aug 19, 2004 | 02:30 AM
race495's Avatar
So is the GU6 a 3.42?
Old Aug 19, 2004 | 07:10 AM
6gear's Avatar
GU4=3.08
GU6=3.42
GT4=3.73
The G80 is what they call a Gov lock, it acts as a open differential untill one tire turns I believe about 100 rpm's faster than the other and then a swinging weight causes both axles to be locked together.
