How can I get more trq?
Old Mar 14, 2007 | 06:29 PM
seadoo's Avatar
Default How can I get more trq?
any bolton's I can do that will improve the low-mid trq of my 04 Sierra 5.3 ?
I know hp comes from trq so i am not concerned with it.
my 5.3 has 330 trq at the fly and 278 at the ground bone stock in 2nd gear.
how can I get my trq to 300 rwtq or more?
Old Mar 14, 2007 | 06:39 PM
dirt track racer 81's Avatar
turbo, nitrous, or supercharger..you take your pic
Old Mar 14, 2007 | 06:44 PM
nightrunner's Avatar
Mr. Obvious
its prolly gonna take that to get there
every bolton might get you there IF you're lucky, bluecajun5.3 only has 330rwhp, 330rwtq, but he's runnin a 12.5 1/4 mile in a rcsb with weight reduction
Old Mar 14, 2007 | 06:52 PM
seadoo's Avatar
my truck is only used for dd and towing...
would perfer bolton's minus F/I or spray.
thanks
Old Mar 14, 2007 | 07:06 PM
zippy's Avatar
Changing the cam can get you a decent torque increase.
Old Mar 14, 2007 | 07:08 PM
Mr. Obvious
here's a list of the boltons that work on our trucks
cold air intake - whatever brand you want, get one with closed filter element and i suggest a dry filter -no oiling t messup the MAF
headers - get long tube and preferably equal-length primaries, get ceramic coating and/or stainless steel for durability
exhaust - make it as free-flowing as possible
tune - get a mail-order tune (nelson performance, wait4me, pcmforless.com, etc.) or even better a live dyno/street tune
efans - get some electric fans, they free up horsepower, 05-up trucks have them and they bolt right it with the combination or a 34" radiator, or retor-fit LS1 f-body fans or get an aftermarket setup
underdrive pulleys - they also free-up horsepower, and consist of an underdrive crank pulley and sometimes an overdrive alternator pulley for the alternator to work properly
gears and lsd - getting lower gears and a aftermarket lsd will make it feel much better, but wont add HP or TQ on dyno
higher stall speed torque converter - will help with take off, and i dont know awhole lot about this some one else can explain it
will probably need some tranny mods for it to hold up to your new power, servos, shift kits etc.
also some mods that are debatable on helping or not are, ported TB, TB bypass,
after this you will need to crack the engine to add cam, heads, etc. for more power without boost or spray
Old Mar 14, 2007 | 07:09 PM
Mr. Obvious
note: aftermarket MAF sensors dont work, neither do tornado, TB spacer
Old Mar 14, 2007 | 07:17 PM
02sierraz71_5.3's Avatar
thanks
The easiest and most effective for towing is a gear change 4:11 will make a big difference, also a smaller diameter tire will increase final gear ratios.
Just about anything to free up air flow, especially exhaust
Old Mar 14, 2007 | 07:55 PM
v8
17,16,15,14,13,12,11 Drvr
Well damn I DD my truck and I have a big cam and all boltons, but then again i'm N/A too ahahaa
go F/I for a great DD you won't be disappointed at all.
Old Mar 14, 2007 | 08:21 PM
bluecajun5.3's Avatar
11 Second Truck Club
yeah and watch the tranny go
f in transmissions
