home made y pipe
Old Nov 17, 2005 | 07:46 PM
02sierraz71_5.3's Avatar
Default home made y pipe
Took off my exhaust today to reweld and track down some exhaust leaks. The enclosed pics are the y pipe and one of the flanges I ground down to get off someone elses bugger welds. Its not the pritties thing but it does its job; not to bad for some monkeys with an angle grinder and a welder.
The pic of the hummer is an H1 we put 20's and 36" terra grapplers on plus some other work.
BTW: It didnt fix my problem with one bank running leaner, so next thing is to have the injectors flowed and rebuilt, I guess thats what I get for buying used injectors.
Attached Thumbnails home made y pipe-exhaust2.jpg   home made y pipe-exhaust3.jpg   home made y pipe-exhaust6.jpg   home made y pipe-hummer.jpg   home made y pipe-hummer1.jpg
Old Nov 17, 2005 | 09:01 PM
Zick's Avatar
Looks Purdy
Old Nov 17, 2005 | 09:09 PM
thanks, its definately a frankenstein backyard exhaust but hell it works and that y pipe cost me around 60 bucks for mandrel bends and flowmaster y
Old Nov 18, 2005 | 01:50 AM
TXsilverado's Avatar
if that hummer was mine i would call it sparky. if them ***** ever hit the street youll know why
Old Nov 18, 2005 | 08:29 AM
TG02Z71's Avatar
Looks good I think, mine is wayyyy uglier.
At least you painted it!!
Old Nov 18, 2005 | 10:01 AM
silver-mod-o's Avatar
Hunt&Fisherator
if you put all that work into building a y-pipe why not just run a little more pipe and make yourself some true duals like I've got.... I have a buddy that built my entire system from the headers back to the tips for 200... he gutted the cats and put on some SLP resonators. all 3 inch pipe. It sounds mean... and runs way better. I think I lost a hair in the torque dept but I definitely gained some HP.... It was a good trade off. my next step is to put in an H-pipe or X-pipe so it balances a little better....
as for running lean... you mentioned re-building your squirters..... no good.... just get some upgraded replacements and have your PCM flashed or get a tuner.... you will be way happier with the results.
Old Nov 18, 2005 | 11:06 AM
I think duals are overkill and you loose power under the curve. Plus you get to pay for twice the pipe and 2 mufflers, then a crossover. The way I setup the exhaust it is stepped down with the thorley tri y headers then into the y and 1 3" pipe.
As far as the injectors these are 31 lbers they flow enough it is something physically wrong with them on one side.
zblee
63
Jun 10, 2023 01:25 PM
GXPJAY
Feb 13, 2022 08:15 AM
06 4.8
Aug 16, 2015 06:16 PM
05GMC4.8
Aug 7, 2015 09:55 PM
