holy Sh** i need help guys
Old Apr 17, 2004 | 09:59 PM
loweredon20s's Avatar
Unhappy holy Sh** i need help guys
ight well i was drivin and i dont kno why i jus stopped and decided to do a nuetral drop i dont kno what the **** happin but as soon as i did it the car didnt go anywhere and the transmission made a funny noise i let offfthe gas completly and then put it in park and it made the noise that if ur moving and put it park it makes that clicky noise i was so fucked cause i didnt kno what to say to my parents cause you kno get the lecture(98 gmc jimmy by the way) i was about to call but i was omg i turned the car off and turned it on maybe i dont kno and i was liek im fucked so i decided to put it on 4wd and it worked jus made a funny noise and i was liek holy **** i looked underneth the driveshaft didnt fall off but i think you kno where it connects into the rearend i thing its still connected jus like snapped inside maybe or did my tranny go? i really need help guys im so fucked
Old Apr 17, 2004 | 10:45 PM
F8L Z71's Avatar
That was smart....
Old Apr 17, 2004 | 10:55 PM
gonzo 6.2's Avatar
based on a lot of thing is the best advise one can give is do everything your parents ask of you,then do more.Sounds like rearend,pinion broke perhaps.
Old Apr 17, 2004 | 11:08 PM
i kno it wasnt smart but how much to fix or would i need a new rear end probaly around 500 to fix?
Old Apr 18, 2004 | 12:11 AM
check and see if it is the rear have a friend (make sure he dont lay in front of the tire)look under it while u put it into gear and see if the drive shaft is spinning and if not it is very safe to assume the tranny is screwed tell your parents that you were driving and the tranny started acting funny and then it just started making the grinding noise
Old Apr 18, 2004 | 01:28 AM
Flyer's Avatar
Neutral slams are retarded ....
Sounds like you blew the rear end out. Jack the back up and turn one tire ... the other tire should turn the other way.
Old Apr 18, 2004 | 08:35 AM
bigguy75inches's Avatar
unless he has the factory locking differential, in which case they should both spin the same way. right?
Old Apr 18, 2004 | 08:48 AM
ACDenali's Avatar
No its a limited slip so one will still turn the other way.
Old Apr 18, 2004 | 11:09 AM
Flyer's Avatar
I know mine does that ....
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
