High Oil Pressure
Old May 4, 2005 | 12:57 AM
Default High Oil Pressure
I seems like my oil pressure has gone up quite a bit in the past month or two. When I hammer on the gas the oil pressure guage jumps to about 78 pounds. I don't have a clue what to check. Just wanted to see if any of you have had this problem and see if you think it will hurt anything.
Old May 4, 2005 | 11:08 AM
silent1's Avatar
That doesn't seem bad by any means. What have you done to your truck? 40psi +/-5 is what the average pressure is at idle, 45-65 at cruise, and 70-80 at WOT.
Old May 4, 2005 | 11:28 AM
budhayes3's Avatar
PT's Slowest Truck
That's about where mine is at also. Over 40 psi at idle, and up to just about 80 at WOT (according to the factory guage).
Old May 4, 2005 | 11:30 AM
Dub Silverado's Avatar
Same here, seems like when im crusin its at about 60
nightmarechevy's Avatar
Mine did that for a while and then went back down a month or so later. I am guessing it is ok because my truck still runs fine, might want to wait for someone else to chime in. Having more pressure should be better than having too little, I just don't know how much is too much.
Old May 4, 2005 | 01:42 PM
jps_2001's Avatar
The general rule is 10 lbs for every 1000 rpm. That is what I was taught all my life. My toy has a 350 in it and it pegs a 80 lbs guage in my dash at idle, It pegs the 120 lbs guage under my hood at wot.
Old May 4, 2005 | 02:20 PM
Maybe I just didn't realize it before. I guess I am just looking for a reason to sale it and get an '05.
superchomper2003
Aug 26, 2015 09:39 AM
Chiphead
Aug 18, 2015 06:53 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
rojeho
Jul 12, 2015 06:10 PM
