hi again
Old Jul 18, 2009 | 06:09 PM
silva_rules's Avatar
Registered User
Default hi again
im thinking to swap my 4.8 to 6.0 on my 2008 silverado
is it a good idea??
will my trans work well with the 6.0 or i will have problems later on??
thanks....
Old Jul 18, 2009 | 08:22 PM
black4.8's Avatar
6.0 swap is always a good idea! tranny will work but not long probably. a beefed up tranny would be a needed to handle added power.
Old Jul 18, 2009 | 08:23 PM
orangeflash05's Avatar
good power gain you would be happy... and yes your trans will work you may have problems later on just depends on how you drive and what you do with it...
Old Jul 18, 2009 | 09:26 PM
Registered User
what do you think i should do??
whats better
if i took the subarban trans will it fit to my truck and work well??
thanks .....
Old Jul 18, 2009 | 10:06 PM
Mangled03gmc's Avatar
Baltimore Whore
A burban trans will be the saem as your truck has unless it is a 2500 truck.. If I had to do it again I would get the built trans first then find a engine... A stock 60 won't last long behind a decent 6.0
Old Jul 19, 2009 | 09:44 PM
JoeGibbSilverado's Avatar
th400........
Old Jul 20, 2009 | 04:49 AM
norris_83's Avatar
for the amount you'll spend in buying a 6.0 block especially here in kuwait, you might as well stick on a magnacharger...
remeber you need a 58x reluctor 6.0, or else you'll run into all sorts of tuning problems..a 6.0 ss engine in the scrap yard runs around KD700-1000. Installation will cost you around KD300-400. Then tuning and all sorts of other bits and pieces.. trust me it will add up.
If your going to stick the 6speed burban trans in, you'll need to speak to speartech and spend alot more.. use a 4l80e out of an 05-06 escalde/denali and that should be well more then enough..
Goodluck with the hunt.
