Hey guys Im new, great page! Anyone else have a mildly built LM7 5.3?
formerly 2low4nd (11-08-2011)
Im just bolting on a LS6 intake, Long tube headers, Comp Cams 235/249 .573/.558 109 LSA. black bear tune, 3200 stall, on my 2000 RCSB 2wd. Anyone running a similar setup?
Planning on running n2o soon too. Figure it will run pretty stout.
Just looking for first hand opinions with similar setups. Also I dont think a 3200 stall is big enough for the cam, i was thinking a 3800 stall would better suit the setup?
Just a few suggestions. The ls6 intake has never really shown a worthwhile gain over the truck intake other than looks.
Also that is a pretty huge cam for a 5.3.
Most will say mid 220's duration is about as wild as you should go.
Ok, i was recommended to join this page from a LS1 Camaro owner who has a built car. He wasnt sure about the limitations of how large of a cam and if the intake really does work well with the 5.3 or not. Im glad i joined, Im about to tear down the motor, and want to make sure i put the money into the correct places with the correct parts, very good. As for intake what would you recommend? As for the cam maybe i should step down to a slightly smaller duration? Something along the lines of a Comp Cams *****' THUMPR Hydraulic Roller Cam 227/241 .563/.546 109 LSA, High performance street/strip, needs 9:1 CR, 2500 stall, intake, gears, and headers, rough idle. RPM range from 2300 to 6600? Or am i still pushing it with the duration???
What are your plans for the truck?
To give you an idea on powerbands, I have a TSP 228R in my 5.3 with stock 862 heads and stock truck intake manifold. My truck still makes good power up to 6800+ with a 228/228 .588 .588 cam. My 3800 stall also doesn't seem quite loose enough for my setup and I have 4.11 gears.
This is the first time im dedicating one vehicle to prostreet quarter mile racing. So im learning as I go. I also plan on putting 100 shot or so to the motor down the road as well.
BTW ive been on the general truck forums for about 5 or 6 years. This is refreshing page motor wise, from just being a member for just the last few hours. I cant wait to talk to more of you and learn and build the correct motor for my truck, Its hard to find a hardcore source for our generation motors.
Another comment would i a 219/233 .553/.536 109 LSA High performance street, stock converter ok, best with 2000 converter & gears, choppy and thumping idle.Rpm range from 2000 to 6400. Would this even better suit what im going for?????????
If your going to make a mild prostreet truck then i would get a cam around 22x/23x 59x/59x and the LSA is up to you, it all depends on if you spray or what setup you run. Call geoff at engine power systems. He can spec ya a cam. The guys a genius
