HEY GUYS
Old Sep 10, 2003 | 01:56 PM
1BADAZZSS's Avatar
Default HEY GUYS
I HAVE A QUESTION. I KNOW THAT SOMEONE ALREADY PROBABLY POSTED THIS A LONG TIME AGO BUT WHAT SIZE FITTING DO YOU USE TO BY PASS THE THROTTLE BODY COOLANT LINE? AND IS THERE ONLY ONE LINE? CAN YOU PICK IT UP AT ANY LOCAL HARDWARE STORE? THANKS
Old Sep 10, 2003 | 02:06 PM
Default Re: HEY GUYS
I went to ACE - picked up a 1.00 brass hose connector - the connector is about 2.5 to 3 inches long - in the plumbing section - I used the OE clamps - I picked up a 3/8 and a 5/16 just in case - did not have to reroute the hose - the 2 hoses came right together - sits right under the throttle body - easiest thing I have ever done. - How much of a difference I dont know - but cooler is better
Old Sep 10, 2003 | 03:04 PM
Brandon Boomhauer's Avatar
I used a plastic hoodie that i had found a picture of when i searched for TB Bypass....
Old Sep 10, 2003 | 03:07 PM
BigTex's Avatar
I just removed the small hose and connected the long one directly to the spot where the small one was. No connector needed.
Old Sep 10, 2003 | 03:10 PM
1BADHD's Avatar
Got a pic?
Old Sep 10, 2003 | 03:49 PM
I did the same as Big Tex. It is easy, just reroute the long hose section, and leave no hoses on the throttle body, you don't need to plug the holes on the throttle, since it is just a straight little tube that goes throught the bottom of the throttle body.
Doing this still gives you a couple of inches of play left in the hose, so it is easy to reroute.
Old Sep 10, 2003 | 03:57 PM
ThunderZ28's Avatar
12 Second Club
here is your answer
https://ls1tech.com/threads/showflat...31&fpart=1
jeff.ellis
Aug 18, 2015 10:34 PM
Stainless Works
Aug 7, 2015 10:08 AM
mrhino
Aug 7, 2015 10:01 AM
kkirwan71
Jul 28, 2015 06:39 PM
kdw8888
Jul 9, 2015 10:52 PM
