help w/ 5.3 intake swap
Old Oct 19, 2007 | 07:04 AM
shanekennedy's Avatar
Default help w/ 5.3 intake swap
got aluminum block 5.3 from 04 buick rainer going in to my 68 camaro
stock long runner intake is too tall for my hood
gm has kit w/ injectors/rails for $530:
http://www.sdparts.com/product/12590...L76L92Car.aspx
anyone see any issues w/ this swap?
would 40lb injectors be too much for 5.3L
Old Oct 19, 2007 | 08:11 AM
bluecajun5.3's Avatar
11 Second Truck Club
yes there is issues.
that intake will not work on a 5.3
it's designed to work with l92 heads found on the new 6.2L.
Old Oct 19, 2007 | 10:25 AM
thunder550's Avatar
High on diesel fumes
Get an LS6 intake manifold. They pop up for sale over on tech fairly often. You'll have to use LS1 injectors with it. What are you power goals?
Old Oct 19, 2007 | 12:08 PM
no power goals, building a commuter car
i do have long tube headers & hptuners, but no plans to go beyond that
Old Oct 19, 2007 | 12:20 PM
Bill Reid's Avatar
I think this would look good under a 68 Camaro hood
Edelbrock Victor Jr... Summit part# EDL-29086
Injector size is dependant on what your power goals are... 40's would work good if you are looking for something like 500 crank horsepower...
Bill
Old Oct 19, 2007 | 12:25 PM
thunder550's Avatar
If you don't care at all about power, pick up an LS1 intake manifold. They should be dirt cheap because everyone swaps them out for the LS6. Just a warning though. The LS1 manifolds are the worst flowing stock intake manifolds out there for the LS-series motors. Get a stock set of LS1 injectors too. Should be pretty damn cheap to pick up all that stuff.
Old Oct 19, 2007 | 12:27 PM
Bill
that would go with the stock look i'm after. haven't seen one for EFI engines. would the stock throttle body mount on top? if not, then what?
Old Oct 19, 2007 | 12:52 PM
elelbrock says this intake usually requires hood modification, which is what i'm trying to avoid
Old Oct 19, 2007 | 12:57 PM
ZZebes's Avatar
you use it with an intake elbow from www.intakeelbows.com and they can make one that will allow hood clearance
OHsixLS3
Dec 27, 2016 09:30 AM
B.love18
Sep 21, 2015 08:31 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
04450r
Jul 24, 2015 01:58 AM
Ketis
Jul 23, 2015 12:37 PM
