Help with Radix
Old Aug 10, 2005 | 08:35 PM
04Denali's Avatar
Default Help with Radix
Had my RADIX installed today, Won't run. Backfired out the intake. Found out there is a leak at the manifold casket. I think there was a post about a guy that had the a problem with a leak also and what he did was swap the radix gasket (red) with the stock one (green) and it salved his problem. any ideas?
also it is torqued correctly and I'm using the magnacharger tune (for now)
Thank for any help
Mark
Old Aug 10, 2005 | 08:56 PM
Give Brian[Blownchevy]a call tommorrow at Magnacharger,I'm sure he can help you figure out the problem in short order.
Old Aug 10, 2005 | 09:21 PM
moregrip's Avatar
what a rush!
who installed it?
Old Aug 10, 2005 | 09:28 PM
KySilverado's Avatar
I used the gaskets that came with the Magnacharger. Think the key is to put the unit straight down onto the heads as close as possible to where it needs to be and have soapy water on the head/intake surface for the slight moves to get it lined up.
Old Aug 10, 2005 | 10:01 PM
04Denali's Avatar
It was installed by a performance shop. Tomarrow he is going to take it off and try the stock gasket.
Thanks for your thoughts
Mark
Old Aug 10, 2005 | 10:03 PM
BlownChevy's Avatar
blownerator
25 Year Member
I heard that you called today, please give me a call on my cell....Number has been PMed.
Old Aug 10, 2005 | 10:13 PM
TurboGibbs's Avatar
Thank for any help
Mark
I'm the one you are probably refering to. My grimlin came back yesturday after a 4 day hiatus. Must not have been the gaskets. Mine may be due to too much boost. Good luck though.
Old Aug 10, 2005 | 10:48 PM
03sierraslt's Avatar
Mjhoward, I noticed in your sig that you are running 11.5psi on a stock tune? Are you refering to the superchips tune? If so I would be a little worried about running lean. Just curious.
Old Aug 10, 2005 | 10:57 PM
Crash Dummy's Avatar
Former Moderator :(
The supplied orange gaskets that Magna Charger puts in the kit are factory AC/Deco parts right from GM they are the ones that have been in every truck since 1999 and there is nothing wrong with them . The green ones are new EPA friendly gaskets that are made from some expensive floracarbon stuff or something like that, that wont let emmisions pass through them. The new Green gaskets are really expensive , like 4 times the amount if money as the orange ones. If your a tree hugger get the green otherwise the orange are just fine if they are installed correctly.
bagged7104SS
Sep 24, 2015 08:42 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
Dave95Formula
99
Sep 14, 2004 06:11 PM
Fun Guy
80
Dec 13, 2003 08:38 PM
